The Gunson Colortune tool
  • Old Man Rock
  • Old Man Rock's Avatar
Re: The Gunson Colortune tool
08 Dec 2013 04:09
#615021
Spot on regarding your feedback no doubt! B)
I believe for the most part usage of the term "Carb Sync" as depicted in the service manuals as Carb Synchronization of the Vacuum levels that most use. Obviously, the Colortune is not in the OEM manuals... :laugh: that refers to Air/Fuel mixtures.
The Morgan unit pretty much states the same regardless if they call it Carbtune.
Now the other little tool that has made all the pieces fall into play is the AF/R gauge.... Now were talking.... B)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • The_Raven
  • The_Raven's Avatar
09 Dec 2013 12:11
#615114
Wow, you have to have a '76 smogged? That's harsh.
That Colortune tool is definitely worth a shot, it would seem. Anything that demystifies what happens in the combustion chamber is a Good Thing.
A question on the O2 sensor: if you're only getting a composite number of all 4 cylinders, is it really that useful as a diagnostic tool? I could see the rationale on a turbo rig though, where leaning out can be... dramatic,
-Mark P.
Salem, MA
Widowmaker, 1982 KZ1000J2 @1100cc
Red Scare, 1994 Honda VF750C Magna
I intend to die from living.
  • Old Man Rock
10 Dec 2013 05:22 - 10 Dec 2013 05:26
#615174
Yes indeed for one faulty carb and you'll see the measured change indeed...
Case in point, recently, after the 1075 build run @ a 65-75 mph run normally see ~ 13.8 - 14.3 AF/R measurement. She burped/hiccuped and I immediately let off the throttle fearing the worst (extreme LEAN condition) especially after blowing the previous engine up (piston #4 disintegrated) ... :blush:
She was running rough and noticed the was measuring ~ 20 AF/R (LEAN), Pulled the ckoke a tad to add more fuel to get home..... Found 2 choke plunger caps had busted thus increased air into the carb bodies...
Freakin polymer threaded plunger caps on these carbs, really? :blink:
Order off to SUDCO.... Replaced caps and carb re-build kits for all O-rings, float valves and float seats etc... and all better.... Purr's like a kitten and my measurements while running inform me she's just where she needs to be regarding my jetting....
These will fluctuate slightly due to time of year (AZ heat or Winter), elevations, humidity, gas (ethanol) etc...
Idle: ~ 10.5 - 11.3
Low - Mid Range ~ 13.5 - 14.3
WOT ~ 14.3 - 14.7
BTW, AZ no longer requires Motorcycle emissions....
Life is good! B)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 10 Dec 2013 05:26 by Old Man Rock.
  • The_Raven
10 Dec 2013 11:09
#615201
It is great to have that information in real time, no doubt.
What are your thoughts on the Sudco carb rebuild kits versus the K&L ones that Z1 stocks? I'm re-doing all 4 BS34s on my J2.
-Mark P.
Salem, MA
  • zukdave
  • zukdave's Avatar
10 Dec 2013 16:12
#615232
When I got the stuff to rebuilt my VM29's (no kit's for them)
from Z1 the peice came with a Sudco sticker so I'd think Z1
source's them from Sudco.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • FaultedGeologist
  • FaultedGeologist's Avatar
  • The truly educated never graduate...
05 Sep 2014 06:49
#646331
zukdave wrote: If the mech. sync is not done BEFORE any tuning you will not get the screw's any were near even
just as OMR said his ain't close to even turn's out.
OK flame on.
Can someone answer this question please? The local bike repair shop owner stated that I needed to resolve the carb issues regarding not getting a cylinder firing and the air fuel mix. Only then would it be worth it to vac sync the carbs. Do I Need to vac sync or perfect the air/fuel first?? Or, do I run air/fuel, then vac sync, then confirm A/F???
Previously my 3rd cylinder was not firing, so I replaced the A/F needles on Keihin CV34 carbs. The 3rd cylinder required around 3-4 turns out to get the exhaust warm.
I just got the Gunson Colortune in the mail, and I am excited to use it.
BTW, here is the most recent manual: gunson.co.uk/items/pdf/Products/G4074-English.pdf
Questions: (pages will not
1) page 12 - Do I have the Variable Choke Carb or Slide Type Carb? Both sound applicable.
2) page 15 - Multible throttle body injection - help...
Clint
1980 KZ750 LTD H4
FSMaunual: kz.bike-night.com/media/GPz750-full.pdf
Stock except for:
New chain and sprocket (530?).
Dynatek Ignition
Manual tensioner on the way.
Buy JIS screwdrivers.
  • Stazi
  • Stazi's Avatar
05 Sep 2014 07:21 - 05 Sep 2014 07:21
#646334
OK flame on.
I think you have to use an iterative approach. Hook up you carb sync manometer, balance the carbs and then tune each cylinder with the Gunson, then check the balance and adjust if necessary and then recheck with the Gunson.. Each adjustment (fuel vs balance) will affect the other.
82 KZ1000-K2 LTD
Last edit: 05 Sep 2014 07:21 by Stazi.
The following user(s) said Thank You: FaultedGeologist
  • Old Rider
  • Old Rider's Avatar
05 Sep 2014 09:14
#646337
To help with carb Sync I found a paper clip the size I needed to set the slide gap. I know some folks use wire and that works as well just figured I would pass along another item.
Old Dogs never Die.
  • FaultedGeologist
05 Sep 2014 09:29
#646340
Old Rider wrote: To help with carb Sync I found a paper clip the size I needed to set the slide gap. I know some folks use wire and that works as well just figured I would pass along another item.
What is the slide gap?
Clint
1980 KZ750 LTD H4
Stock except for:
Dynatek Ignition
  • JR
  • JR's Avatar
05 Sep 2014 09:39 - 05 Sep 2014 09:40
#646343
OK flame on.
I think you have Keihin CV 34 carbs in which case:
1 you don't have slide type carbs so can disregard the slide gap. Your choke lever operates a choke flap also called a butterfly which blocks air from the air box
2 you don't have fuel injection so no throttle bodies
Last edit: 05 Sep 2014 09:40 by JR.
  • FaultedGeologist
05 Sep 2014 10:52
#646345
JR wrote: I think you have Keihin CV 34 carbs (YES) in which case:
This makes sense now... slide=up and down, flap=rotation on center line.
So am I able to do one tune, then the other; or back and forth in search of unity? Any further confirmation of order or strategy would be great. Digging back in to the carbs and red wine...
Clint
1980 KZ750 LTD H4
Stock except for:
Dynatek Ignition
  • JR
  • JR's Avatar
05 Sep 2014 12:31
#646347
Like Stazi said in his post #646334 above. Good advice
