kawaski kz750 ltd h1 1980
- zig
19 Jun 2012 22:09
ok had carbs cleaned and at low idle it dogs at high its great take off sucks replaced carb holders sprayed carb clean all over carbs no leaks getting real madd lol any suggestions
Re: kawaski kz750 ltd h1 1980
19 Jun 2012 22:14
What are you using for air filtration?
- zig
19 Jun 2012 22:18
i have stock air box and stock kehin carbs its a 1979 bike but made in dec of 79 so it list for parts as an 80
- zig
20 Jun 2012 22:07
so any ideas what i should look at took spark plugs out all 4 are fine sparyed more carb cleaner on and all around carbs vacuum lines no leaks some times when bike is siting their i smell gas i see some very little coming from over flow hose when i take off i got to rev it up to take off rpm when iddling is at 1k but when i crack it open it aint smooth it heasits then picks up
20 Jun 2012 22:28
Did it have this problem before having the carbs cleaned? Ed
- zig
20 Jun 2012 22:50
yes it did my brother sent carbs out to be cleaned he said it got better i bought the bike for 200 its in great shape so i sprayed carb cleaner and found carb holders wher leaking bought new ones still leaked so i put some ruber stuff around them all it worked great no more leak i have a set of other carbs off a 1979 suski gs 750 misso carbs sorry cant spell to good lol but its got a slid choke and thorttlle is hooked up differnt and butter flys are on the inside never seen that so im stuck on this this capta is a pain also lol
- zig
20 Jun 2012 22:52
io been running sea foam in gas but it isnt helping it out i get real bad gas milage too
- Proxy
- 80% Human 20% Nuts/Bolts
20 Jun 2012 22:57
How about float height. Check fuel level.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- zig
20 Jun 2012 23:04
how do i do that i never really messed around with any of this for floats and stuff but wouldnt they have set all that when carbs where sent out
20 Jun 2012 23:25
Here is Patton's excellent clear tube fuel level test writeup:
kzrider.com/forum/11-projects/465836-z25...t=20&start=60#529077
- zig
21 Jun 2012 15:33
No eBay APP ID and/or Cert ID defined in Kunena configurationok bike ran great today and i didnt do nothing but i think my stator is bad i can get one on eby ? is are all stators for the kz 750 the same hers the link please dont buy it lol
- zig
21 Jun 2012 18:27
will this fit a 1979/1980 kz750 ltd h1 for light cover 1981 Kawasaki 305 KZ305 CSR Tail Light Taillight r these the same need a tail light lens covor too
