Carb Sync instructions 79 kz1000
  • davem
  • davem's Avatar Topic Author
22 May 2012 22:54
#524158
I am sure there is directions somewhere on here on syncing carbs but i cant find it. I didnt have much luck when searching the archives.
I am looking for detailed instructions on syncing the carbs on my 79 kz1000.
Can someone point me in the right direction? My manual doesnt have it in it.
Thaanks
A resource for a factory service manual would be great as well.
1979 Kz1000 B3 LTD
1997 Kawasaki police 1000
1985 kz1000p4 project-sold
Re: Carb Sync instructions 79 kz1000
22 May 2012 23:11
#524163
davem wrote: I am sure there is directions somewhere on here on syncing carbs but i cant find it. I didnt have much luck when searching the archives.
Thaanks
Check KZr's FILEBASE (search manual) to locate FSM for Z1-900 (contains sync instructions), and several carb topics that include sync info.
Attachment filebasekzr.jpg not found
Here are two direct links:
Click > www.kzrider.com/filebase/search_result
Click > www.kzrider.com/filebase/doc_download/43...asaki-service-manual
Good Fortune! :)
22 May 2012 23:19
#524164
Thaanks
You really should put your year/model in your signature; that way folks might be able to be more helpful. I know you state you have a 1979 KZ1000, but is it a 1979 KZ1000 A3; A3A; B3; C2; or E1? It does matter if you’re trying to find the manual. Ed
  • davem
22 May 2012 23:26
#524166
Thaanks
Sorry! its a 79 kz 1000 ltd b3.
Ill try to add to signature
1979 Kz1000 B3 LTD
  • davem
22 May 2012 23:40
#524170
Thaanks
The carbs seem to be differnt on that model. i dont see an adjustment screw on mine.
Mine is a 79kz 1000 b3 ltd.
Good Fortune! :)
Thanks for your help!
1979 Kz1000 B3 LTD
22 May 2012 23:41
#524171
Attachment addsig.jpg not found
Good Fortune! :)
22 May 2012 23:42
#524172
No eBay APP ID and/or Cert ID defined in Kunena configurationI could not find an original Base Service Manual for the '79; maybe someone else can say which reprint would be appropriate, but here's the "supplement" for the B3:
  • davem
22 May 2012 23:46
#524173
Good Fortune! :)[/quote
I got it.
Thanks
1979 Kz1000 B3 LTD
22 May 2012 23:49 - 22 May 2012 23:56
#524174
davem wrote: ...dont see an adjustment screw...79kz 1000 b3 ltd....
Am thinking the carbs are manual slide carbs (not CV carbs).
Sync adjust screws are under each cover on top of carb.
Mixture adjustment screw is probably located so as to be reached from the bottom , on the engine side of carb.
Should also be a single idle adjustment screw that regulates closed throttle slide position on all carbs.
Good Fortune! :)
Last edit: 22 May 2012 23:56 by Patton.
  • davem
22 May 2012 23:49
#524175
650ed wrote: I could not find an original Base Service Manual for the '79; maybe someone else can say which reprint would be appropriate, but here's the "supplement" for the B3:
Should I get the supplement if I dont have the manual origional manual to go with it?
1979 Kz1000 B3 LTD
22 May 2012 23:55
#524176
Should also a single idle adjustment screw that regulates closed throttle slide position on all carbs.
Good Fortune! :)
Forgot to mention that the bottom-located pilot mixture screws may still have the factory non-tamper plug hiding access to each screw. The plugs are removable, but be very careful to drill a very shallow hole into the plug (don't hit the underlying screw) whereby a sheet metal screw may be inserted to grip and pull on to remove the plug.
Good Fortune! :)
22 May 2012 23:59
#524177
davem wrote: ...Should I get the supplement if I dont have the manual origional manual to go with it?
Yes, and also get the standard model manual when it becomes available.
It's best to have both the basic manual and the LTD supplement.
Good Fortune! :)
