Carb Sync instructions 79 kz1000
  • davem
  • davem's Avatar Topic Author
Re: Carb Sync instructions 79 kz1000
26 May 2012 12:35
#524937
Patton wrote:
davem wrote: ...Should I get the supplement if I dont have the manual origional manual to go with it?
Yes, and also get the standard model manual when it becomes available.
It's best to have both the basic manual and the LTD supplement.
Good Fortune! :)
I found the manual at kawasaki.com. thanks for the tip.
couple questions...
I bought a vacuum guage from harbor freight(mainly because I cant find a sync tool locally and wanted to get this done this weekend.)I did the sync acording to my clymer but only used one guage one carb at a time. I recorded the reading and moved on to the next carb.DO YOU SEE ANY ISSUE WITH DOING IT LIKE THiS instead of all 4 hooked up at once?
The only thing I couldnt get exact before the sync was fuel mixture. Bike ran pretty decent but 2 --4 cylinders were lean based on plug readings. I just couldnt get them to change.
I synced each carb to 10-11 Inch
The bike runs goood but still not 100%
I get a small variation idle speed. There is no air leak at carb mounts.
Timing is set
advancer and everything in there operates as it should and is oiled.
The bike has 4 into 1 yoshimura exhaust stock airbox except the piece under the seat after the air filter is not attached. This was missing when I got the bike but the bike ran great untill i tooke the carbs off for cleaning and I changed the oil.(to change oil I had to remove the exhaust system)It has 112.5 main and 117.5 pilot
It really sucks when you cant get everything to go back 100%
1979 Kz1000 B3 LTD
1997 Kawasaki police 1000
1985 kz1000p4 project-sold
  • Motor Head
  • Motor Head's Avatar
26 May 2012 12:42
#524941
www.kzrider.com/filebase/doc_download/215-simplevacsynctool
try on of these simple tools, it will let you know right away if 1 carb is pulling more Vacuum.
Very sensitive to your adjustments.
The following user(s) said Thank You: Archiddeon
  • davem
27 May 2012 10:17
#525124
Motor Head wrote: www.kzrider.com/filebase/doc_download/215-simplevacsynctool
My manual calls for specific measurements. How do I determin the measurements with this tool?
Should the carbs still be tuned to the specs in my manual with the aftermarket exhaust and not complete airbox?
1979 Kz1000 B3 LTD
27 May 2012 10:30
#525129
Personally, I wouldn't try to use a tool that did not show the vacuum on all 4 carbs at the same time. When synching the carbs any adjustment to 1 that affects the idle speed can affect the vacuum being drawn by the other carbs, so it's nice to be able to watch them all at the same time so the affect of adjustments across the entire carb rack can be seen real-time. I'm not saying you could not synch the carbs using a single vacuum tube, but it could make the process very slow and frustrating. Ed
  • TexasKZ
  • TexasKZ's Avatar
27 May 2012 10:44
#525136
The exact reading is not as important as having them all the same and you are right about the mods affecting the readings. That said, generally the higher the vacuum, the better.
  • TexasKZ
  • TexasKZ's Avatar
27 May 2012 10:47
#525139
P.S. 650ed is right, reading all four is easiest, but you have to be able to read at least 2 at a time.
  • kaw-a-holic
  • kaw-a-holic's Avatar
27 May 2012 11:32
#525150
That is going to be a very painfully experience. I had a buddy with experience help me with mine. You really need the correct tool. Every time you adjust 1 they all can change a bit the ammount of adjustment will be different on each one. IMHO, take your time and use the right tool on this one.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • Motor Head
27 May 2012 11:48
#525156
This tool won't have any specific vacuum makings or #'s. It is a very simple way of seeing which carb is pulling more vacuum than another. It is very easy to build, costs hardly anything, is very sensitive to the slightest changes you make. It can set those carbs up nicely. Not to different from using a clear tube to see your float bowl fuel level.
  • richrand
  • richrand's Avatar
28 Jun 2012 16:37
#532402
Top. I'm syncing my carbs and the needles are bouncing EVERYWHERE. there's no dampening adjustment on the manometers. What the best way to settle the gauges down? Would clamps on the hoses work?
Also, I've got the carbs where you need to take the caps off to adjust them but removing them creates a vacuum leak. Do i just go ahead and sync them as is? I don't see any way around it.
  • badrhino
  • badrhino's Avatar
11 Jul 2012 23:31
#535368
That's what I was wondering. I have 29mm smoothbores and was wondering how you adjust the carbs with the tops off. Would they not leak because of this? :blink:
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • LarryC
  • LarryC's Avatar
12 Jul 2012 08:44
#535406
badrhino wrote: That's what I was wondering. I have 29mm smoothbores and was wondering how you adjust the carbs with the tops off. Would they not leak because of this? :blink:
A lot of old 29 smoothbores leak like crazy around the slides when you do a carb synch. There's a simple way of addressing that situation.
Larry C.
  • TexasKZ
  • TexasKZ's Avatar
12 Jul 2012 09:09
#535408
Is this what you have in mind, LC?
www.dynoman.net/carb/keiCR.html#cr29s
