Leaking Intake boot fixes?
  • Yotaracer4life
  • Yotaracer4life's Avatar Topic Author
13 Apr 2012 17:49
#515632
Would it be a bad idea to try to seal leaking intake boots with silicone?
  • moneypit
  • moneypit's Avatar
Re: Leaking Intake boot fixes?
13 Apr 2012 17:59
#515635
It will eventually fail
Just buy new ones
z1enterprises.com
2-76 kz900
St Paul MN
  • richrand
  • richrand's Avatar
13 Apr 2012 17:59
#515636
you need to make sure whatever you use it can withstand the temps and the fuel. I've used permatex form-a-gasket 2.
  • T_Dub
  • T_Dub's Avatar
13 Apr 2012 18:46
#515639
New ones don't leak.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • Medina
  • Medina's Avatar
13 Apr 2012 20:32
#515654
I used black RTV on a honda I had a couple of years ago, held up for the entire season, sold the bike- to a local- he knew about the jury rig, to my knowledge he hasn't replaced them.
They aren't exposed to anything but air if I'm not mistaken. RTV takes the heat.
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
13 Apr 2012 21:46
#515660
60 bucks for new ones. Hole in piston 10 X 60. New ones are soft and easy to work with. Roy
  • Yotaracer4life
13 Apr 2012 21:50
#515661
I disocered that the screws that go into the head were just loose, I didnt think to check that before since ive never taken them off, What happens when its ridden to long with leaking boots?
  • gengomerpyle
  • gengomerpyle's Avatar
13 Apr 2012 21:52
#515663
i used the copper colored RTV stuff. the guy at the autopart store said it holds up to fuel better
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • T_Dub
  • T_Dub's Avatar
13 Apr 2012 21:55
#515664
Yotaracer4life wrote: What happens when its ridden to long with leaking boots?
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • T_Dub
  • T_Dub's Avatar
13 Apr 2012 21:57
#515665
I dont use anything to seal these. Clean the head surface, put them on, don't take them off until you have a new set to put on in twenty years. They're rubber with a metal plate inside, if you torque them down they'll seal to the minimal pressure they'll see.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
13 Apr 2012 23:04
#515674
seal em, many do some dont, rubber weakens over time, and no a TEMPORARY fix is OK, silicone em if it keeps u on the road for a few weeks, just dont push it, a poor man riding on a budget is OK ;)
  • Garn
  • Garn's Avatar
14 Apr 2012 20:22
#515818
The one thing I've noticed over the years is that... Often replacement screws are too long for the upper part of the rubber manifold, causing them to bottom-out. In fact, these upper screws are in a blind hole, unlike the bottom screws and thus, cause you to think you have them tight, allowing an air leak.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
