Leaking Intake boot fixes?
  • saxonpirate
  • saxonpirate's Avatar
  • 1983 KZ1100 LTD
Re: Leaking Intake boot fixes?
14 Apr 2012 20:56 - 14 Apr 2012 21:04
#515824
Unless the boots are absolutely knacked ie : split or has hard as concrete, there's no shame in sealing them. And if you haven't got the dosh, well...no brainer.
Like all tasks, big or small, you just need to make good neat job to the best of your abilities, and use a good quality sealant. I always use Hylomar Universal Blue. It's stood the test of time in many industries, and is non-setting which always helps if you need to get things apart at a later date. Technical information at the URL below
www.newmantools.com/chemicals/hylomar.htm
1983 KZ1100 LTD..
Ride like your life depended on it :-)
Last edit: 14 Apr 2012 21:04 by saxonpirate.
14 Apr 2012 21:44
#515836
T_Dub wrote: New ones don't leak.
+1 That sums it up.
  • saxonpirate
  • 1983 KZ1100 LTD
15 Apr 2012 05:13
#515872
+1 That sums it up.
I agree entirely 650ed.......but!
For some people the depth of their pocket does dictate, especially if they're biking on a budget. As I said above "Unless the boots are absolutely knacked ie : split or has hard as concrete" sealing the mating surface between the boot face and the intake manifold holds no problems as long as the job is done properly with a good sealant. After all, isn't this what motorcycle maintenanance is all about.
A little skill, forethought and ingenuity goes a long way to keeping you on the road...
1983 KZ1100 LTD..
  • Medina
  • Medina's Avatar
15 Apr 2012 08:00
#515883
saxonpirate wrote: After all, isn't this what motorcycle maintenance is all about.
Almost........Zen like post!
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
15 Apr 2012 08:22
#515884
saxonpirate wrote: ...Hylomar Universal Blue....
Sounds interesting, but wondering about long term durability under simultaneous exposure to both heat and gasoline.
For example, Permatex represents some of its products as heat proof, and other of its products as gasoline proof, but not one that's both heat proof and gasoline proof.
Any of the temporary sealing fixes for carb holders are imo likely better than nothing (and probably outlast some girlfriends).
Good Fortune! :)
