PVC Airbox w/ pods
- kcornell6
PVC Airbox w/ pods
01 Oct 2011 16:38
Spent $15 on the piping for this new airbox type of thing. Something I came across, even though it may not be necessary to install, was a valve. So at the opening, just put another pipe that has an adjustable valve. This will change the amount of air coming through is there's too much because of the new pods. Might not look all that great, but would sure get the job done without adjusting carbs. Could adjust the amount of air coming through if you go from a high elevation to low also if your carbs are set up for higher areas.
No cutting needed. Fit all together like it was made for the carbs
V/R
Kev
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
81 GS850L
- wireman
Re: PVC Airbox w/ pods
01 Oct 2011 16:59
filters?
- Old Man Rock
01 Oct 2011 17:00
Whoa... :blink: Well have to give you some kudos on ingenuity....
Round filter in the end pipes?
Once you get the valves working, take this prototype to a metal shop/machinist and have these puppies made with aluminum tubing...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- wireman
01 Oct 2011 17:10Attachment mrturbofilter.jpg not found
now you just need a couple of these
- indianajames
01 Oct 2011 17:12
looks cool , i had a similar idea . mine used 4 tees with short lengths in between and where they go into boot for hose clamps. these carbs seem to function better when drawing from same air mass , sort of like a 4 into 1 , not a 4 into 2 with no crossover tube. with useing only 2 pod filters you may not have to re jet. i used 2 single barrel filters for cars , mine worked great after i drilled 4 , quarter inch holes around the exhaust end plate that holds the baffle in . sounded bad ass , not too loud . ran great
- peter1958
01 Oct 2011 17:38
Could put a toilet seat on it too match
www.kzzone.com/
- 750steve
01 Oct 2011 18:00peter1958 wrote: Could put a toilet seat on it too match
You're a bad man! :evil: :laugh:
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- P21
01 Oct 2011 20:05
looks good but you need to put the boots in order (orientation) just saying
Kawasaki KZ 1000 Police (2002) P21
- Boostable
01 Oct 2011 20:12
Interesting concept for sure... keep us posted.
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
01 Oct 2011 20:28
With the additional weight of the filters, won't this thing need some support to keep from falling off or cracking the intake manifolds?
- hal0tw0
01 Oct 2011 22:11
I dig the concept and execution, but arent pods on CV carbs the kiss of death tuning wise?
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- Godfrey
01 Oct 2011 22:43
I been collectin info for a home made airbox from here, keep the ideas comin.
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
