My tale of woe and misery
  • havakaw
  • havakaw's Avatar Topic Author
20 Aug 2011 22:27
#470496
OK:>So I had to replace the OE carbs on my '80 750 LTD h a coupple of years ago.I transferred all the internals over to the "new" ones I got off E-bay.Come to find out,they were from an '83 "F" model.They worked allright,but really never had the low end power I needed,untill it warmed up.So this year,after about not riding it for about a month an a half,I went to go take it out.The tank was bone dry.So I go and put about a gallon of 50:1 weedwacker gas in it I had floating around. It wouldn't run at all.Drain the tank and the carbs,put in 2 gallons of fresh gas.Still won't run.It sounded like it was "Fluttering" and would really only run "Good" between 7-9000rpm.Take the carbs appart.I had an extra set of slow jets from the OE carbs,and they were 35's.Got the smallest drill bit(#70) from the toolroom at work,drilled them out,reassembled.Dropped the mains from 142 down to 125.(Got an 810 kit,V&H pipe,Big K&N's.)After torching all the carbon build-up off the plugs,it fired up!!!Ran good,but was obviously WAAAYYY too rich.Off with the carbs,back in go the 35 slow jets.Doesn't run again!!!Test the compression.145-155 across all 4.Check the pick-ups.Left side is bad.WHAT!?!?!It was just running!!!Swap out the pick-ups with a spair set from my 1100.RUNS!!!(P/U lead wires are about 6 inches too short,but that's another story)Order a set of 48 slow jets.Then #2 Piolet screw starts to jam up on removal.NOOO!!!Go to "Made in China"tool outlet store,and buy the $100 tap and die set for the 6x.75 T&D to clean up the threads.Piolet screw won't go back in.NOOO!!! Come to see that the spring has gotten all effed-up down in the hole.Got it out,screw threads right in,thank GOD!!!But it's still way too lean at low sppeds,but at least I got a clue about where to go with this.OMG,it's been a hell of a week.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
  • havakaw
Re: My tale of woe and misery
20 Aug 2011 22:36
#470503
Oh yeah>I forgot to add that I thought that maybe the advancer wasn't working right,so I checked it,and yup,it was hanging up.Took THAT all appart,cleaned,lubed and re-checked it.It snaps back real nice now,not hanging up about half advanced.So,to re-count:Electrical issues,2.Carb issues at least 3.And this thing was RUNNING before I put it away.Just goes to prove,nothing is as simple as it seems.
'80 KZ 750 LTD-H
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
21 Aug 2011 01:50
#470572
and thats why god invented beer :woohoo: :woohoo:
