installing carbs with airbox
  • OregonMatt
  • OregonMatt's Avatar Topic Author
18 Aug 2011 21:03
#469856
is there some trick to installing the cabs with the stock airbox? the PO trashed the stock box leaving only the screens and boots(his idea of an air filter was to tie a bandana around it). I have been running pods, but recently got a stock airbox off of ebay. so far it has proved to be a bitch to get on. is there any tips I am missing? Thanks
1976 kz 900
  • bountyhunter
  • bountyhunter's Avatar
Re: installing carbs with airbox
18 Aug 2011 21:06
#469857
Soak the rubber boots in boiling water for a while to soften them up before installing.
  • 's Avatar
18 Aug 2011 21:28
#469860
I dont think there is a trick per se to getting the box on.Several things I learned taking mine on and off a few times: Be sure the intake manifolds that bolt the carbs to the intake are either new or in good shape.If not replace.Same is true for the rubber boots that connect rear of carbs to airbox.When reassembling,leave everything loose until allparts are mated and in proper position-then tighten everything down.Move airbox as far to the rear of the frame as u can to give urself some wiggle room.I use a little KY jelley on the rubber parts to get them to slip over the carbs. I also use a stiff piece of plastic to run around the inside of the rubber boots after installing to ensure nothing is folded over or kinked.I have found that a six pack also helps as does some Scotch whiskey and a good mastery of Anglo-Saxon 4 letter expletives. Some folks find that sliding the rubber boots that connect the carbs to box inside the box and pulling them out over the carbs after they are installed works,but it didnt for me.Mucho good luck.bj
18 Aug 2011 22:50
#469882
Roll them back on themselves when installing carbs; then unroll them onto carbs.
  • KZ_Rage
  • KZ_Rage's Avatar
  • Kentucky Bourbon Barrel Ale
18 Aug 2011 22:54
#469884
OregonMatt wrote: ...so far it has proved to be a bitch to get on. is there any tips I am missing? Thanks
Nope, you haven't missed a thing, its a bitch, the roll back trick is about it when using a stock air box. Oh and don't try the roll back with dry/hard boots, not going to work and bad things will probably happen.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
  • Proxy
  • Proxy's Avatar
  • 80% Human 20% Nuts/Bolts
18 Aug 2011 22:56
#469885
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
