float height?
- jacksdad
- 1979 kz 750 OUCH, IT SPARKED
float height?
23 May 2011 11:11 - 23 May 2011 11:20
1979 kz750 twin cyl.
Last edit: 23 May 2011 11:20 by jacksdad. Reason: petcock is good
Re: float height?
23 May 2011 11:32 - 23 May 2011 11:33jacksdad wrote:so this morning when i put fuel into the 1979 kz750, it flowed right through the left carb and onto the ground via the over flow tube, the motor was cold, does this mean that I have to adjust the float height again, i did that a few weeks ago, and the problem went away, but now it is back. thanks for any feed back.
Would be more suspicious of a dirty float valve as the most common cause of float bowl overflow.
Typically crud or grit between the float needle's pointed tip and the orifice in the float seat.
Where seats are removable, each float needle is supposed to remain with its own particular seat.
Mismatching the needles and seats during reassembly may result in failure to completely seal, which allows excess fuel to enter the float bowl.
Might try this --- With engine idling (and fuel discharging from the overflow hose), use a plastic mallet or large screwdriver handle to rap smartly and repeatedly against the float bowl. Which sometimes helps the float valve to resume fully sealing.
Last edit: 23 May 2011 11:33 by Patton.
- jacksdad
Re: float height?
23 May 2011 12:14
thanks, i just spent an hour trying to start it, it finally started and i take it down to the end of the street, where it stalls, as i am pushingit back, my neighbor(who seems to know alot about alot) said that a strimg battery woild help the bike fire better, even when running, is that true on older points fored bikes, or is he wrong?
Re: float height?
23 May 2011 12:26
My bike will not run worth a damn when the battery is dead (or near dead) even though the charging system works well. If your battery is shot replace it or you'll be chasing all kind of ghost problems. Ed
- jacksdad
Re: float height?
23 May 2011 13:05jacksdad wrote: even on points fired ign.?
My bike is a 1977 KZ650-C1, and yes, it uses points not electronic ignition. Ed
- jacksdad
Re: float height?
23 May 2011 18:49
ill be getting one tomorow, walmart brand are ok right?
Re: float height?
23 May 2011 19:08
Should be. I've always used Sears Die Hards with good results. Ed
- jacksdad
- jacksdad
Re: float height?
24 May 2011 12:33
walmart would not le t me ruturn the battery i had bought about 4 weeks ago, no receipt, but they did test it for me and said that it was ok just needed a charge, i came home and put it on the charger(slowest setting, 2amp) when i went to the bike to do some cleaning, i happened to turn the gas on and gas came out of the overflow, as well as the breather line, eventually it quit, but theat sure was a lot of gas, that carb was FULL, hope everyhtings ok, ill know in a few hours when the battery is done(hopefully)
Re: float height?
24 May 2011 12:39
You should try to track down the fuel overflow problem so it doesn't happen again; it could be dangerous. Also, check your oil for fuel contamination. If that much came pouring out of the carbs some may have gone into the engine as well. Ed
- jacksdad
Re: float height?
24 May 2011 12:43
whats the best way to check the oil for fuel contamination?
