float height?
Re: float height?
24 May 2011 12:47
#453255
Syphon a little out through the filler hole and give it the sniff test. Also, you might try to see if a capfull will light with a match, although it would probably take a high percentage of gas to do so. Ed
  • jacksdad
  • jacksdad's Avatar Topic Author
  • 1979 kz 750 OUCH, IT SPARKED
Re: float height?
24 May 2011 12:51
#453257
what should i do if there is gas in there?, drain it out a refill it?
1979 kz750 twin cyl.
  • btchalice
  • btchalice's Avatar
Re: float height?
24 May 2011 15:22
#453288
if it has gas in the oil , definitely replace it as it will be severely reduced viscosity
wouldn't want you to risk your engine bearings
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
The following user(s) said Thank You: jacksdad
