KZ1000 air filter, Clamp on or stock airbox...
  • Thecreeper77
  • Thecreeper77's Avatar Topic Author
13 May 2011 19:22
#450772
What are the major differences? Pros and cons of both?
1980 KZ1000
2008 Versys
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: KZ1000 air filter, Clamp on or stock airbox...
13 May 2011 19:29
#450773
Unless you have serious engine mods, those clever Japanese engineers knew how to make KZ's run well. Stock airbox. I have a running KZ1000A1 and I'm converting back from pods to a stock airbox...if I can ever locate a stock system (they are rare as most were pitched in favor of the pods).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Thecreeper77
13 May 2011 19:39
#450775
As far as I know the bike only has been moded with 4-1 VH system. Would you say there is no real difference? Its just an esthetics thing?
1980 KZ1000
2008 Versys
  • dshelly
  • dshelly's Avatar
13 May 2011 21:20
#450796
If you don't mind tinkering with the carbs the pods will flow more air. But, if you just want to ride it, stick with the airbox and just drop in a foam or K&N type filter. Pods are defineatly easier to pull the carbs, but they can also screw with the mixture on a windy day.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • grumpy56
  • grumpy56's Avatar
13 May 2011 22:28
#450817
Another vote for the stock box here.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
  • bgmrc
  • bgmrc's Avatar
15 May 2011 00:13
#451075
pods and jet chage and then possible a needle adjustment and the bike will pull harder then ever...
strictly my opinion as to the results i got!!
  • FreddaAbborre
  • FreddaAbborre's Avatar
15 May 2011 05:17
#451116
Don't forget that pods spounds sweeeter....:p
But is the airbox realy that expansive? Didn't found very much on ebay, a completed listing ending at close to $90 for an airbox with silencer doesn't seam very much to me. Sure it's more than $28 for 4 pod filters, it's not like finding an original exhaust in decent condition at a fair price...
Moto Martin Z1 -73
Z1000 A1 -77
Z1000 A2 -78
Z1000 Mk.II -80
(and a pile load of junk)
  • Thecreeper77
15 May 2011 13:53
#451205
Thanks for the input guys, I think Ill go with the PODs.
I am in the process of trying to find a owners and service manuals, Anyone know what size PODs the 80 kz1000 shaft drive takes?
1980 KZ1000
2008 Versys
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
15 May 2011 16:47 - 15 May 2011 16:49
#451231
Pods will basically ruin the low end performance and some of the fuel economy of the bike.
Think of a high peformance speaker with a tuned port, thats what an airbox is. Its acoustically tuned to boost flow performance in the areas that the engine struggles to produce smooth power on its own. Especially during the first few thou rpm during the transition from initial to full advance. Back pressure, and tuned port intake are responsible for the smooth, as linear as possible power that Kawasaki engineered.
PODS, on the other hand allow you to bypass the theory of smooth street power for a nice boost in pull at higher rpms. you absolutely must rejet and tune the bike for the new air flow characteristics that will be dependant totally on the setup and condition of your engine : begin expierementation mode :P You'll get a lumpy, then flat, then boosty feel across the rpm range with OK tuned pods, some like it, some dont.
Go with whatever you feel like, but for those who know... airbox is the only option - and the power gains of pods, can be had with an airbox, it just requires lots more modding.
PEACE.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 15 May 2011 16:49 by TeK9iNe.
  • racer54
  • racer54's Avatar
15 May 2011 16:56
#451232
If you go with the pods...get a good brand. There is lots of difference between brands. I have always had good luck with K&N filters and I have heard the APE filters are good ones also. Some of the cheaper models are just that. They don't last very long and are very restrictive, so check them out before buying. As in lots of things, you get what you pay for with pods...get a good set the first time!
  • Thecreeper77
16 May 2011 16:16
#451481
Thanks guys for the input. I think I still go with the POD for the look and for the better top end. My other ride has great bottom and mid range. This will be something new and different for me as well i thin kit will go better with the look i am trying for.
1980 KZ1000
2008 Versys
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
16 May 2011 16:33
#451483
does your bike have cv carbs?
i have heard that cv carbs and pods have there own issues.
