KZ1000 air filter, Clamp on or stock airbox...
- Thecreeper77
Re: KZ1000 air filter, Clamp on or stock airbox...
16 May 2011 16:51
cv carbs?
1980 KZ1000
2008 Versys
2008 Versys
- KZShafted
16 May 2011 16:53
I am using Emgo pods on my Shafty and they are 48mm. They came from
www.crc2onlinecatalog.com/
I am not advertising just helping!
1980 KZ1000 Shaft
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
- KZShafted
16 May 2011 16:58
Sorry I think the pods were for another bike!
I will look up the correct part and get back with you!!!
1980 KZ1000 Shaft
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
- KZShafted
16 May 2011 17:06
The pods were the 42mm Emgo and you can get them at
www.z1enterprises.com
or even at
1980 KZ1000 Shaft
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
1995 KZ1000 Police
1974 Cb450 Cafe
1981 Yamaha Seca550
- Kidkawie
- I bleed premix
16 May 2011 17:34FreddaAbborre wrote: Don't forget that pods spounds sweeeter...
Pods sound like ass IMO. The engine sounds like a big water bong unless you are 1/2 throttle or more. I switched back from pods to the stock airbox on my Z1 and was never happier. As far as having more pull? Throw on a 16t front sprocket.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
16 May 2011 17:38
constant velocity.
they use a vaccum diaphragm to lift the slide rather than a cable.
16 May 2011 18:03Thecreeper77 wrote: Thanks guys for the input. I think I still go with the POD for the look and for the better top end. My other ride has great bottom and mid range. This will be something new and different for me as well i thin kit will go better with the look i am trying for.
Pods :laugh: How much time do you really think you'll spend driving at 8000+ rpm :laugh:
- Thecreeper77
16 May 2011 21:42650ed wrote:Thecreeper77 wrote: Thanks guys for the input. I think I still go with the POD for the look and for the better top end. My other ride has great bottom and mid range. This will be something new and different for me as well i thin kit will go better with the look i am trying for.
Good point!
1980 KZ1000
2008 Versys
2008 Versys
- Thecreeper77
16 May 2011 21:44
Ive seen "one piece" PODs. Any difference or gotchas there?
1980 KZ1000
2008 Versys
2008 Versys
- Polar_Bus
19 May 2011 07:07
This very question is asked probably a million times on virtually every motorcycle forum "pods vs. airbox. Generally speaking for every 1 person that has achieved TRUE sucess with pods on a street driven application, there is 20 (I killed my low to midrange power) horror stories. I 100% agree with others that CV type carbs and pods do NOT work well together "out of the box" on the street. The key term here is "STREET". You can get pods to work effectively, but you better seek the proffesional services of an experienced tuner with a dyno. Then if the ambient air temps deviate say more than 20 degrees from which you initially had your tuning performed, now you engine is incorrectly jetted anyways. I tried podding a older GS750E years ago and what a friggin PIA nightmare to jet, NEVER got the bike to run decent, when I did i lost about 6 mpg ! So just do yourself a HUGE favor....keep your airbox, and add a richer pilot jet, and shim the stock needles if you have OEM jetting and if you have a pipe. Just ride and be happy on the street
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
- Sackman
19 May 2011 10:59
I guess I'm 50/50 on this subject. True that the japs designed the bikes to run efficient and very well with the stock airbox, no if ands or buts about it. But for those individuals who desire a different "look" then pods are a viable alternative.
With that said, there is a great amount of "tinkering" that needs to be done when running pods with or without pipe changes. I put pods on my 84 nighthawk 700 and ran 4 into 2 home made pipes with no baffles and it ran like crappolla. I had to run bigger main and pilot jets and spent a good deal of time tweeking the fuel mixture screws and then syncin the carbs. I never put it on a dyno so I'm pretty sure it could be off slightly but after running plug chops and riding the bike for a few months I have been able to tweek the carbs for pretty good performance. I will say that my gas milage isn't the best but I didn't build the bike for that reason. I built it for me and what I like.
So, I guess it depends on individual tastes, and how much "tinkering and tweekin" a person wants to do to obtain something that looks and or performs differently. I like my bikes loud so I prefer to change things to suit me and for me that means jetting the carbs and tinkering.
Check out my blog at backyardbikechoppin.blog
or
Sackmans Choppers
77 KZ 650 Chopper
84 Honda Nighthawk Chopper
98 Vulcan 1500 Classic
or
Sackmans Choppers
77 KZ 650 Chopper
