Carbs leaking LOTS of gas
- gnstalodz
11 May 2011 03:45 - 12 May 2011 23:31
I know of the drain screw for the carbs, and I used that after cleaning my carbs, but after I tightened them to stop the leak it just kept going and going. It's tightened all the way and it's just pouring out? I tried the search but didn't see anything.
ps. The bike hasn't ran yet and it pours out when the bikes off
Carb problem. Videos attached
81 440 ltd
Last edit: 12 May 2011 23:31 by gnstalodz.
- wireman
Re: Carbs leaking LOTS of gas
11 May 2011 04:08
have you tried replacing the o ring or washer?
- gnstalodz
11 May 2011 04:29
didnt even know there was those in the carbs...
81 440 ltd
- wireman
11 May 2011 04:36
if its leaking from the drain screws on bottem of carbs there should either be a gasket or an o ring depending on which carbs you have
got a picture of the carbs,what model of bike?
im getting too old to remember what everybody else rides,cant remember what i rode/drove in on most days! :blink:
:woohoo:
- gnstalodz
11 May 2011 05:44
Sorry I edited my sign
And it's leaking from the very bottom, the rubber hose
81 440 ltd
- DoubleDub
11 May 2011 08:40
Sounds like the overflow - that would be a sticking float valve or improper float height.
11 May 2011 08:54gnstalodz wrote: didnt even know there was those in the carbs...
See diagram:
Attachment KZ440.jpg not found
11 May 2011 09:16
While engine idles (and fuel discharging from overflow hoses) ---
Rap smartly against sides of float bowls, using a plastic mallet or large screw driver handle.
Sometime helps freshly cleaned float valves to get fully seated, and often without future leakage.
11 May 2011 09:24 - 11 May 2011 09:24gnstalodz wrote: ...And it's leaking from the very bottom, the rubber hose
The diagram posted by 650ed doesn't show an overflow circuit on the oem carbs.
With overflow circuits, there are usually four drain hoses attached to the nipples at bottoms of float bowls, and the four drain hoses are routed to exit underneath the bike.
Last edit: 11 May 2011 09:24 by Patton.
- gnstalodz
11 May 2011 16:06Patton wrote:gnstalodz wrote: ...And it's leaking from the very bottom, the rubber hose
What rubber hose?
Is there a nipple protruding downward from the bottom of each carb float bowl?
Yea, the hoses that run underneath the bike. And it's a 440 so there are only two.
I'm trying to think of what I did wrong so I'm just gonna take apart the carbs again I guess
81 440 ltd
- gnstalodz
11 May 2011 16:06DoubleDub wrote: Sounds like the overflow - that would be a sticking float valve or improper float height.
yes, the overflow is what I'm tanking about
81 440 ltd
- gnstalodz
11 May 2011 17:04
floater spring is bad... anyway to fix it?
81 440 ltd
