Carbs leaking LOTS of gas
- gnstalodz
Re: Carbs leaking LOTS of gas
13 May 2011 06:30
I only have two lines from the petcock, but I'll check again tomorrow. And I know about gas, I'm in the bay area haha... ouch
81 440 ltd
- DoubleDub
13 May 2011 10:04gnstalodz wrote:DoubleDub wrote: 1. Find, buy, steal a manual.
2. Still could be the needle binding when the float isn't all the way up, in fact it still probably is.
which needle?
Float, it controls the fuel flow to the float bowl.
- DoubleDub
- gnstalodz
13 May 2011 23:50DoubleDub wrote: Again, a manual would be very helpful here.
I'm guessing it's my float height. I need to get a cheap manual somewhere. ebay time
81 440 ltd
14 May 2011 00:55
eBay is loaded with them. Just be sure to buy a Kawasaki factory manual not clymers or haynes; and be sure it covers your exact year/model. You'll love it! Ed
- austin3119
14 May 2011 02:38 - 14 May 2011 02:40
"While engine idles (and fuel discharging from overflow hoses) ---
Rap smartly against sides of float bowls, using a plastic mallet or large screw driver handle.
Sometime helps freshly cleaned float valves to get fully seated, and often without future leakage.
Good Fortune! "
+1. Great post. Also add some Seafoam to your tank. Start the bike up, let it run for a minute or two and shut it down. Head out to the garage the next morning, crank her up, and hit the road for a nice ride
Good Fortune! "
Last edit: 14 May 2011 02:40 by austin3119.
- DoubleDub
14 May 2011 12:07gnstalodz wrote:DoubleDub wrote: Again, a manual would be very helpful here.
Unless someone messed with the float heights in the past or the floats were swapped they should be fine.
- gnstalodz
14 May 2011 18:58
Here is the needle height on the one which is leaking. It's a hair higher than the other and it's not fully resting it looks.
ps. The bike currently isn't running so any test with it on aren't gonna work
81 440 ltd
- Motor Head
14 May 2011 19:03
That's not the float valve needle, you are looking at the needle which controls the mid range fuel delivery. That's not what controls the fuel in the bowl, or causes fuel to leak out vents.
- gnstalodz
14 May 2011 20:53Motor Head wrote: That's not the float valve needle, you are looking at the needle which controls the mid range fuel delivery. That's not what controls the fuel in the bowl, or causes fuel to leak out vents.
ok im happy the doesn't effect anything, that diaphragm had to be replaced and I used a ebay one haha
81 440 ltd
