Idle Problem
Re: Idle Problem
16 May 2011 23:15
#451615
  • BIGKEVIN
  • BIGKEVIN's Avatar Topic Author
Re: Idle Problem
17 May 2011 06:36
#451666
I have 12 volts going into the ignition on the white wire with the key off. When the key is turned on, the voltage drops to about 6 volts. I didn't have this problem until I started checking wiring in the head light. I did spray electrical contact cleaner into the key switch hole and the wiring on the back of the switch. Now as soon as the key is turned on the voltage will drop from high 11 volts/low 12 volts to about 6.5 volts.
1976 KZ900
2006 ZX6R
Re: Idle Problem
17 May 2011 09:30
#451683
Probably already have this, but here's a link to the full wiring diagram found under KZr FILEBASE.
Click > www.kzrider.com/filebase/doc_download/264-z900a45
Good Fortune! :)
  • BIGKEVIN
Re: Idle Problem
17 May 2011 13:38
#451720
Those are the diagrams that I was using to check the voltage. I also noticed that now my turn signals dont work. I am trying to trace down that is causing this.
1976 KZ900
2006 ZX6R
