Deacceleration popping
  • filztoy
  • filztoy's Avatar Topic Author
23 Feb 2011 03:30
#432849
Heys guys I'm new here and this site has been great in bringing my 1980 Kz 1000 LTD back to life.Only 1 problem exhaust popping on decel.I checked everything from valves clearances to timing, vacumm leaks, fuel levels set to 4mm,the Vm28's seem to be dial in with 17.5 pilots and 122.5 mains,I'm running pods and a Russ Collins 4 into 1. I got this bike about a year ago and rode it while bringing her back to life.I've taken exhaust temps and #3 seems to be cooler but all plugs are the same color any thoughts.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Deacceleration popping
23 Feb 2011 03:37 - 23 Feb 2011 03:46
#432852
"exhaust popping on decel."...
If all other variables good to spec (manifold no leaks, no holes in exhaust/couplings, jets good, carbs sync'd etc...) >>> Running a tad lean... Change needle clip position for richer ops...
NOTE: May also be due to colder climate temps/higher elevations... Was this occurring in the summer temps as well.... ;)
Either way, 1 clip change richer, and go for a ride....
Hold at 65mph and let go of the throttle so she snaps back... Still back fire... Yes/No...
Same test, hold steady at 65mph ~ 4500-5000rpm.. She stumble, surge a tad as she would be needing gas....
If no to either above then good to go....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 23 Feb 2011 03:46 by Old Man Rock.
  • filztoy
23 Feb 2011 03:53
#432856
I'll try the next day it gets above 40 degrees, Thanks
23 Feb 2011 04:40
#432865
Could first try slightly enrichening the pilot circuits, say 1/4 turn of the adjuster screws.
For side-located air screw, turn clockwise 1/4 turn (reduces air).
For bottom-located mixture screw, turn counter-clockwise 1/4 turn (increases mixture).
Good Fortune! :)
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
23 Feb 2011 12:34 - 23 Feb 2011 12:41
#432928
Although im not sure this bike has the Air Circulation ports on top of the valve cover that run back to the airbox via hoses, for emissions, I know that can cause some popping on decel problems if not working correctly.
You can remove the whole system, plug the ports on valve cover, as well as the hole in airbox.
Just a thought.
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Last edit: 23 Feb 2011 12:41 by 550A2.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
23 Feb 2011 13:30
#432935
Mine was popping quite a bit until I sealed my intakes.
To verify it was indeed an intake problem, I squirted a little bit of gas on the rubber intake boots (between the carbs and the head) while the engine was idling. When I'd squirt the gas, the engine speed would pick up due to the increase of gas being sucked in.
To correct the problem, I pulled the carbs off the boots and sealed the head to intake boot with some high temp silicone. Runs like a charm now!
Gotta say, I like a little popping though. Within reason of course. :P
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • filztoy
23 Feb 2011 14:24
#432943
Thanks to all,I'm pullin the carbs tomorrow,I see what looks like a crack on #3 holder on the inside with a mirror.I'll keep ya posted
  • mtbspeedfreak
24 Feb 2011 14:16
#433155
Your Russ Collins exhaust, does that say "RC Engineering" on the plaque on the muffler?
2000 ZRX 1100
  • filztoy
24 Feb 2011 14:35
#433162
Yes it does.
  • filztoy
24 Feb 2011 14:38
#433163
Performance Products
  • Polar_Bus
  • Polar_Bus's Avatar
25 Feb 2011 04:49 - 25 Feb 2011 04:50
#433286
Decel popping can also be a bad cyl head to pipe exhaust gasket seal. I've also seen rust holes in the exhaust cause popping. I had a cheap MAC exhaust on my GS1100E that had an annoying decel pop, and I finally ended up running double copper crush gaskets in the head and popping was eliminated.
Bikes:
'84 GPz1100
'06 HD Fatboy
Last edit: 25 Feb 2011 04:50 by Polar_Bus.
  • filztoy
25 Feb 2011 11:32
#433361
Thanks, but I've already been down that road,that is was I thought it was at the begining and replaced all crush gaskets with new ones and cleaned the head and header flange.I pulled the carbs off yesterday and sure enough #3 carb holder has a crack in it time to replace um, we'll see what happens next week when I get it back together.
