Deacceleration popping
Re: Deacceleration popping
25 Feb 2011 11:53
i have heard that the carbs being out of sync can cause popping on decel.
just hearsay so take it for what it is worth.
killer lookin bike btw. :evil:
- mtbspeedfreak
25 Feb 2011 12:32
filztoy wrote:
Awesome! Where'd you get the pipe? Did you paint it back yourself?
Yes it does.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- Polar_Bus
25 Feb 2011 13:30
filztoy wrote:
OK, than really the only other cause is most likely too lean a pilot jet.
Thanks, but I've already been down that road,that is was I thought it was at the begining and replaced all crush gaskets with new ones and cleaned the head and header flange.I pulled the carbs off yesterday and sure enough #3 carb holder has a crack in it time to replace um, we'll see what happens next week when I get it back together.
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
- filztoy
25 Feb 2011 13:52
It came on the bike when I bought it.I'm the 4th owner, the original owner did all the mods back in '80(jets,pods 4-1) the other 2 owners really treated it like shit, when I bought last year it had 15 years of road kill and grease on it. I got a lot of hours in it just cleaning not to mention tuning but it's worth it I was 18 yrs old when this bike came out and didn't have the money to buy one,at the time I ridin a 69 Triumph trophy 650. Yes I had my buddy media blast the pipe and I shot some black on it. Wonder what the pipes worth today?
- hocbj23
- mtbspeedfreak
25 Feb 2011 16:47
hocbj23 wrote:
I'll give you $25.00 for it!!!
$14.95
2000 ZRX 1100
- filztoy
- gengomerpyle
26 Feb 2011 16:55
i just took my bike out and its doing the same thing with the popping. i guess ill try replacing the exhaust gaskets and see if that helps before i have the carbs checked. i really havent ridden my much lately.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- Kapahulu
18 Mar 2011 22:56I put some GS1000 carbs (non-pumper) on my '79 KZ1000 with 20 pilots and 120 mains. The bike had been running great except for loud exhaust popping. I just turned the air screws 1/4 in and that got rid of most of the popping.Patton wrote: Could first try slightly enrichening the pilot circuits, say 1/4 turn of the adjuster screws.
For side-located air screw, turn clockwise 1/4 turn (reduces air).
For bottom-located mixture screw, turn counter-clockwise 1/4 turn (increases mixture).
Thanks Patton!
2strokeworld.com
2strokeworld.com
- mark1122
- Keep twisting it
19 Mar 2011 12:45 - 19 Mar 2011 12:46
Just some info regarding the exht gaskets.
It is common to have flange fit issues with aftermarket exht systems. If u find that u run out of thread on the flange bolts u can use 2 gaskets to get a better seal. Z1E also sells thicker gaskets for this reason.
please gont spray gas to check for air leaks. WD-40 is safer.
hope this helps others.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 19 Mar 2011 12:46 by mark1122.
- cperrotta
04 Apr 2011 14:22
I have the same problem when decel'n. I took a look under the bike at the H crossbar (whatever you want to call it) where the gaskets would be, and noticed a small amount of pressure coming out of the 1 side. I haven't replaced it yet, but I did losen it up, put exhaust gasket silicon in and closed it up again. That fixed the problem for about a week until the silicon failed. So I'm going to have to replace that gasket as well now.
