How does a float valve stick???
  • 550A2
  • 550A2's Avatar Topic Author
  • keep the shiny side up
09 Nov 2009 12:12
#332380
I know its a dumb question but im kind of in a jam right now.
So my bike is running like crap! 82kz550a2
-It sounds like its only running on a couple cylinders.
-Fuel is POURING out of the air box drain when i try to run it.
-It wont idle and has terrible throttle response.
I figured it was a stuck float valve. But isnt it suppose to come out of the overflow's???
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • YUKABODOS
  • YUKABODOS's Avatar
Re: How does a float valve stick???
09 Nov 2009 12:24
#332382
Try pulling the drain screws on the bowls of the suspected carbs to flush out any crud. Also give it a tap - a - roo with a rubber mallet or a place a piece of wood against the carb body and wack it with a hammer. This may unlodge a stuck float.
This has happened many a time to may a rider. Also, I have found that this problem was caused by a bad petcock before as well.
Of course someone will tell you to run an inline fuel filter and if the problem is not resolved by aforementioned low tech remadies then it maybe time to pull and clean those carbs.
Good luck. The smell of raw fuel is almost as bad as the problem itself.
09 Nov 2009 12:25
#332383
Would check for fuel intrusion into crankcase via sniff test and examining physical condition of oil. And not again run engine until changing oil and filter, and correcting the carb overflow issue.
Overflow circuit likely clogged, and perhaps overflow hose is kinked or blocked.
Probably crud in the float valve, and time for carb removal, disassembly and cleaning.
Remember to install a fresh inline fuel filter, or two filters if dual fuel lines are fitted.
Good Luck! :)
  • 550A2
09 Nov 2009 12:31 - 09 Nov 2009 12:34
#332385
THanks for the quick replys!
Yeah, an oil change is coming soon.
ive drained the bowls twice, and did a little tapping with no results.
I actually did take the carbs off and blew out the main's and pilots, and the circuts.
But i neglected the float seats now that i think about it, I thought they were working when i had them on the bench because every float bowl filled up and stopped, but they werent all to spec so i adjusted the tang's and the float level is fine. But the problem is still there.
Should i take the bowls off and maybe take out the float needles and blow the seats out?
Last edit: 09 Nov 2009 12:34 by 550A2.
  • PLUMMEN
  • PLUMMEN's Avatar
09 Nov 2009 13:01
#332391
take the float out and make sure its not full of fuel while youre at it B)
  • YUKABODOS
09 Nov 2009 13:41 - 09 Nov 2009 14:06
#332402
If the carbs look clean and you have addressed the needles and seats and the problem persists, then check the petcock.
I had the same problem and after replacing the petcock with a new suzuki from Z1 the problem stopped and I have not had any trouble since.
A good question would be, which carbs are leaking 2 & 3?
Last edit: 09 Nov 2009 14:06 by YUKABODOS.
  • JR
  • JR's Avatar
09 Nov 2009 14:03
#332409
If the float needles have little black rubber tip then these can wear and the needles may need to be replaced - cheap, usually, at least cheap for my 750. The other thing which might be worth doing is to soak a Q tip cotton swab in carb cleaner and run it around the carb seat. Works for me. If carb cleaner on a Q tip does not work then you could try Brasso.
  • 550A2
09 Nov 2009 15:14
#332422
Thanks for the help!
i think mostly 1, cause i blew the cylinder out with compressed air and it was flooded and FULL of gas, i mean alot sprayed out.
Im gonna do some reading to see if they are suppose to rubber tips, then ill break em open again and clean em out real good.
If it still does it, then ill look at the petcock.
what would i be looking for in the petcock?
  • ArthurGoVroom
  • ArthurGoVroom's Avatar
  • I'd rather ride it than shine it
09 Nov 2009 15:57
#332434
I like the metal-polish-on-a-Qtip-in-a-dremel-tool trick for cleaning and polishing the inside of the needle valve seats. Worked for me.
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
  • hoghaterkaw
  • hoghaterkaw's Avatar
09 Nov 2009 16:11
#332437
the petcock's job is let fuel reach the carbs. the float needle and seat's job is to hold the fuel level. you need to look inside the carbs and find out why the fuel is not shut off when the fuel comes up to the correct level. as said that is the job of the float needle and seat.
  • keith1
  • keith1's Avatar
09 Nov 2009 16:28
#332441
as much as i hate to admit it, he s right......
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
09 Nov 2009 17:46
#332460
Part of the key here is finding out why your overflow circuits aren't working either. Even if your needle/seats aren't doing their job, the gas should end up on the ground not flooding your cylinders.
Get right or get left! <*{{{><
