Petcock (pet cock...say what?) Question
- badrhino
08 Sep 2008 17:17 - 08 Sep 2008 17:30How should this set-up look and can anyone tell me what each individual nipple actually is for?:dry:
I am running 29mm Smooth Bores:woohoo: on the bike if that makes a difference in hose lines being ran to the carb.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
Last edit: 08 Sep 2008 17:30 by badrhino.
- Sandy
- Fly High,Tony
Re: Petcock (pet cock...say what?) Question
08 Sep 2008 18:27
Do yourself a favour...get rid of that petcock and get one that's going to actually WORK for those smoothbore carbs.
The Pingel high-flow petcocks are pricey,yes,but so worth it.
www.z1enterprises.com/reference/petcock.aspx
1977 KZ1000 A-1
- badrhino
08 Sep 2008 18:41 - 08 Sep 2008 19:02
Damn, that's about half of what I paid for the bike!:blink:
Anything cheaper, way cheaper?
Also, the petcock has On/Res/Pri on the dial. I read in another thred that this is a vacuum operated one, but there is no lines hooked up to a vacuum.:S
Franken Z!
Franken Z!
Last edit: 08 Sep 2008 19:02 by badrhino.
- Sandy
- Fly High,Tony
08 Sep 2008 19:01
LOL...yah,I hear ya,but seriously...they're worth the money.
You could ask,and see what petcocks(single outlet) are compatible to your bike.
I'm sure someone here might have something for you...or Ebay?
1977 KZ1000 A-1
- RonKZ650
08 Sep 2008 20:08
The way your petcock is rigged should still work. There is no vacuum line hooked up currently, so you'd have to always run prime to get fuel. Also capping off a fuel line with a bolt is going to leak I would imagine. If it was me, being a cheapskate and all I cared was function, I'd get new 1/4 fuel hose, and run a short length of hose of each larger nipple, so the one that's capped off, plus the one with the kinked line. Run these two lines to a 1/4" T fitting and tee off a single line to your carbs, then get 3/16" line and take from one of the unused vacuum nipples on your 4 intake manifold rubbers up to the smaller nipple on your petcock. If all is working on your petcock, vacuum will be present with the engine running to operate the petcock as intended, and I doubt highly you'll starve for fuel unless you're getting <15mpg dragracing all day
- badrhino
09 Sep 2008 12:39
All of my vacuum nipples are free to be used. Right now the number 1-3 nipples are tubed together and the 2-4 nipples are ran together as well. That is how it was when I bought it. This whole bike is somewhat of a nightmare but it is going to be sick when I get finished sorting it out.
Franken Z!
Franken Z!
- badrhino
09 Sep 2008 12:41
Also my cock-pet says On/Res/Pri. Is there anyway to shut this off? :dry:
Franken Z!
Franken Z!
- mtkawboy
09 Sep 2008 12:53
It will shut off in the on position with no vacuum to it
- badrhino
09 Sep 2008 16:54
Sooo, you're telling me the petcock doesn't let fule flow unless there is a vacuum? The tank is off the bike now and there is gas running out the one hose. I don't understand.
Franken Z!
Franken Z!
- RonKZ650
09 Sep 2008 17:31
Only on prime should gas flow all the time. In the on or reserve position gas should not flow unless vacuum is applied to the smaller nipple on the petcock. If gas flows all the time in the on or reserve, the vacuum diagphram in the petcock is bad. Only $10-$15 part.
09 Sep 2008 18:38 - 09 Sep 2008 18:39
My understanding is that with engine off (no vacuum), an internal spring and o-ring block fuel flow in ON and RES positions.
When functioning correctly, vacuum from running engine sucks the diaphram to overcome the spring pressure so the o-ring no longer blocks flow.
In PRI position, the spring and o-ring don't block the flow, so fuel flows through petcock regardless of whether the engine is running or not running.
Would assure the spring and o-ring are also in good condition.
Good Luck!
Good Luck!
Last edit: 09 Sep 2008 18:39 by Patton.
- badrhino
14 Sep 2008 12:22
OK, now I understand. Thanks for the info.!
Franken Z!
Franken Z!
