Carb. mount boots?
- steve3408
Carb. mount boots?
07 Jul 2008 17:19
Whats the general consensus on changing the mounting boots,if they dont appear to be cracked or leaking,just old and original,like 20 + plus years old?
1980 KZ1000 A4(bought new),1979 KZ1000 MKII(bought new),1978 KZ1000 A (sold)1979 KZ1000 B LTD (sold)1976 KZ900 LTD (sold)1978 KZ750 twin (sold)
- Bullitt03737
Re: Carb. mount boots?
07 Jul 2008 17:29
Dont fix it if it aint broke! Why mess with a good thing?
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- RonKZ650
07 Jul 2008 17:30
Don't touch them unless they are bad. Many times the mount screws are corroded in the head and will twist right off.
- 1978KZ
07 Jul 2008 19:52
At $60.00 for for pieces of rubber I would be very careful with them, and like bullitt said "If it ain't broke"
1978 KZ1000 A2, 2008 Honda Ruckus, 2004 Nissan Titan
- steve3408
07 Jul 2008 19:58
Yeah, i guess i'll treat 'em like a sore pecker and not screw with it.They "look " ok but after 20 something years i just wasnt sure whether to do them or not,since i have the carbs. off,this would be the time to do'em.Sure dont want to fight the air filter boots any more than i have to,theyre the worst part of that job.
- wiredgeorge
08 Jul 2008 11:08
I like to replace carb holders at least every three years. They may not LOOK bad but they harden and won't seal well. They are not intended to last for 20 years for sure. I view carb holders as consumables, like plug wires, plugs and other tune up parts. That is just me.
- OLTIMER
- Back when I was your age, ...
08 Jul 2008 18:36
And where do you find them? Z1E? Someplace else?
I need manifolds for a 78 KZ 650 D1, and all I can find is one side (can't remember, left or right), and for $not-too-cheap also.
wiredgeorge wrote:
I like to replace carb holders at least every three years ...
1978 KZ650-D1 SR
Sioux Falls, SD, USA
The shortest distance between two points is under construction.
- Thistle
08 Jul 2008 20:19
I bought the carb boots from Z1 last year. I think they were around $60 for 4. They are only available for the one side but the only difference is the rotation for where the vacuum plugs go. Not a problem for the capped one, but the vacuum line is a bit of a stretch on the other. Mine also looked good and never really noticed a difference with the WD40 spray test, but changed them (and the air box boots) and it made a world of difference. Not only performance, but pliable so much easier to get the carbs back on - and off again and on again as I forgot to put the carb boot clamps on first;)
I do have one question though.... where can you buy the vacuum line in a long roll? Would like to replace (and lengthen) these lines.
Dave.
Dave.
KZ550C1 1980
KZ650H1 1981
KZ650H1 1981
- anarki650
08 Jul 2008 20:52
+1 on changing them out. I've replaced two sets that "looked good" but weren't. Pick up the ones from Z1 and just flip whichever side upside down. While you're placing an order from Jeff, pick up a new set of airbox boots too, you'll be happy you did.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- cmmman
08 Jul 2008 23:06
Thistle wrote:
Silicone hose in any size available here, mostly sold by the foot.
www.hosetechniques.com/
Dave.
1977 KZ650B, modified.
- NiagaraZ
10 Jul 2008 09:57
If it doesn't pass th WD 40 test change them out, I put up with rough running for too long. Did mine recently and now she runs beautifully. Money well spent.
Had to pull the airbox and use a small impact driver to get the screws out, replaced the screws and put some anti-sieze on them. The impact driver is a "must have" for working on these old machines
78 KZ650 D1
- mtkawboy
10 Jul 2008 13:28
The factory ones seem to hold up better then the aftermarket ones but they cost more too.
