1983 kz750 fuel line size
- jon0108
19 May 2008 16:09
i have one fuel line from my petcock to the carbs. I need to know what size(i.d.) it is, i dont want to guess, its either 1/4 inch or 5/16 inch. Anyone know for sure?
- jon0108
- tv219
Re: 1983 kz750 fuel line size
25 Oct 2012 16:54
How did it end up fitting? good choice? I need to replace my line as well. thanks
Bensalem, PA
25 Oct 2012 17:01
I use 1/4". It's a snug fit, so I guess either size will work ok. The inside diameter of the petcock outlet tube is just shy of 1/4" so either size will flow enough fuel. Ed
25 Oct 2012 19:07
On my 81 KZ650-CSR the fuel line is 5/16" & the vacuum line is 1/4".
- loudhvx
25 Oct 2012 20:34 - 25 Oct 2012 20:39
On on the later models, they went to a larger fuel line. I think it's nominally 8mm. The closest to that is 5/16".
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 25 Oct 2012 20:39 by loudhvx.
26 Oct 2012 10:54
Some prefer a snug enough fit whereby a clamp isn't needed.
If the fuel line is difficult to fit onto the nipple, the end may be immersed for a few seconds in near boiling water, which softens it enough to slide easily over the nipple.
26 Oct 2012 11:55Yep. 1/4" is way too tight for the fuel line, increasing the risk of pulling out the nipple... don't ask how I know. hee. It's an easy fix.loudhvx wrote: On on the later models, they went to a larger fuel line. I think it's nominally 8mm. The closest to that is 5/16".
26 Oct 2012 14:10martin_csr wrote:Yep. 1/4" is way too tight for the fuel line, increasing the risk of pulling out the nipple... don't ask how I know. hee. It's an easy fix.loudhvx wrote: On on the later models, they went to a larger fuel line. I think it's nominally 8mm. The closest to that is 5/16".
Interesting. On mine it's a snug fit, but not nearly tight enough to pull the nipple loose. Mine has the original 1977 non-vacuum petcock. Of course, it could be that the automotive fuel line I'm using is actually a tad over 1/4" even though it is marked 1/4" or maybe it's more pliable than some other types. Ed
- loudhvx
26 Oct 2012 14:36martin_csr wrote:Yep. 1/4" is way too tight for the fuel line, increasing the risk of pulling out the nipple... don't ask how I know. hee. It's an easy fix.loudhvx wrote: On on the later models, they went to a larger fuel line. I think it's nominally 8mm. The closest to that is 5/16".
What did you do to fix it? I had one come out, but I was lucky and it pressed back in snugly.
1981 KZ550 D1 gpz.
Other links.
Other links.
26 Oct 2012 15:47 - 23 Jan 2013 12:28I used Permatex Liquid Solder. I believe their Liquid Metal is basically the same product.What did you do to fix it?
Apply a small amount on the outside of the nipple, then simply press it back into the petcock orifice. very easy.
Last edit: 23 Jan 2013 12:28 by martin_csr.
- undiablo
29 Oct 2012 15:47
YEs, 5/16".
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
