Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis.
01 Jun 2022 16:25
#868006
Your corrector jets are installed correct.
  • zed1015
  • zed1015's Avatar Topic Author
  • Away
02 Jun 2022 02:14 - 02 Jun 2022 03:00
#868021
Thank you for the update. I’m concerned now. I just installed your corrector jets into a Suzuki set with both air and fuel pilots screws. Please look at included photo. Hopefully I got the right. Thank you.
Yes! They are correct.
It's only some sets of KAWASAKI VM26 with a singular fuel screw that are not handed.
It does not occur on any of the Suzuki carbs or Kawasaki VM28's.
Last edit: 02 Jun 2022 03:00 by zed1015.
  • Surt
  • Surt's Avatar
04 Jun 2022 12:42
#868230
DOHC wrote: Can you tell us what size these are. It looks like the recommended BS30/97 air jets for the VM29 are "0.9". I don't know if that number is an actual measurement, or just a part number. But I'm interested in which size BS30/97 your parts are most similar to.
The BS30/97 jets perform exactly the same function as these but they will not fit the VM 24 through 28 as they are smaller at 4mm and would just fall into the air bleed passage .
I would say the 0.9" is a code or part number as that equates to a massive 22.86 mm and even 0.09" is 2.286mm which is still too large.
hi mate, doesn't 0.9 mean 0.9mm in metric system, not square miles in the imperial one?
ZN750 Ltd Shaft (non-USA)
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
04 Jun 2022 14:42 - 04 Jun 2022 14:51
#868236
Watch this video about the Metic vs. the Imprial system and form your own opinion.
Last edit: 04 Jun 2022 14:51 by Scirocco.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
04 Jun 2022 18:06
#868245
The truth about the impiral system you don´t know, it´s obsolete.
  • zed1015
  • Away
05 Jun 2022 02:47
#868261
Yes! Mikuni main air jet sizes are measured in fractions of a millimeter.
The smoothbore main air jets are in increments of 0.1mm and come in sizes from undrilled to 2.0mm  to allow very fine adjustment on the day for track type ,altitude, type of fuel etc to try and achieve the ideal fueling and response needed for racing at the time.
The following user(s) said Thank You: Surt
  • Surt
  • Surt's Avatar
05 Jun 2022 09:39 - 26 Feb 2026 07:55
#868277
thanks Zed, now question is can't one re-drill the stock air jets with a 0.9mm bit and call it a day? i'd love to buy your kit, but doubt that  you'll be able to ship it to Russia, so i'll have to coup with my own hands
Last edit: 26 Feb 2026 07:55 by KZQ.
  • zed1015
  • Away
05 Jun 2022 10:30
#868278
No!
The stock VM air restrictor which is pressed in and integral with the carb body is 2.6 mm and the corrector jet ( which is not 0.9mm for this application) has to be threaded in to the air passage ahead of it.
The BS30/97 smoothbore jets are m4 thread and are too small for the stock VM's air passage which has to be threaded m5 .
I've had no previous problems shipping worldwide including Russia but with the current situation i'm not sure if postal deliveries have been suspended.
  • Surt
  • Surt's Avatar
05 Jun 2022 12:36 - 26 Feb 2026 07:58
#868289
No!
Last edit: 26 Feb 2026 07:58 by KZQ.
  • zed1015
  • Away
05 Jun 2022 12:44 - 05 Jun 2022 13:17
#868292
yup i meant boring of the stock restrictors rather than tapping m5 thread and installing your corrector jets. probably a big ask to get known the needed orifice i.d.
You can't bore the stock restrictor .
They are already bigger than the corrector jets.
Drilling out the stock restrictor any larger will exaggerate the lean condition.
Last edit: 05 Jun 2022 13:17 by zed1015.
The following user(s) said Thank You: Moose1800
  • Moose1800
  • Moose1800's Avatar
05 Sep 2022 07:53
#873379
Huge thank you zed1015!, I received my choke plungers and air corrector jets for my Mikuni VM 28's . The work you did with the plungers looks great ! I installed them and got my carbs back together and the ole girl fired right up and idled great, impressive for a set of carbs that are almost 50 years old. It's been raining here all weekend so no test ride yet maybe later today if the roads dry. The throttle response feels great and the idle is smooth. I didn't install the corrector jets just yet as I'm running an old bread box air filter and it may be a bit more restrictive than pods so a test ride in order.
Thank You zed1015 I'm a very happy old Zed owner !!!!
The following user(s) said Thank You: zed1015, SWest, Mikaw
  • Moose1800
15 Dec 2022 07:23
#877834
Received my second set of plungers from zed1015 yesterday. If your planning on rebuilding a set of Mikuni VM carbs the rebuild won't be complete if the plungers aren't reconditioned and zed has been doing this for quite some time. You can trust his work......Thanks zed !!!
The following user(s) said Thank You: zed1015, SWest, Mikaw, howardhb, Wheelhop
