Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis.
- gordone
Re: Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis.
28 Jan 2021 21:44
Ahh from top... then it was as stock position then.
You suggest I try to run the engine without doing any modification then or shall I go back to 15 pilot jet?
Project:
Project:
- zed1015
29 Jan 2021 01:19
All settings should reman stock apart from the main jet.
- gordone
29 Jan 2021 03:26zed1015 wrote: All settings should reman stock apart from the main jet.
Still when I have 750 with 810 bigbore and using VM24 carbs ?
Project:
Project:
- zed1015
22 Mar 2021 08:46 - 22 Mar 2021 08:47
Just a little update on the choke plunger repair service.
I can now repair pretty much all rubber tipped MIKUNI plungers of both 8mm and 10mm diameter heads which covers most Kawasaki, Suzuki and Yamaha machines including CV carbs.
Hopefully this will also be of help to those running KZ and non KZ machines where these components are obsolete and no longer available new.
Last edit: 22 Mar 2021 08:47 by zed1015.
The following user(s) said Thank You: TexasKZ, Mikaw, gordone, Scirocco
- gordone
21 Apr 2021 14:06
Test drived first time today with the jets.
seems to have nice performance increase
before it was not going smoth with midle throotle (steady) and high RPM typical on highway, today it was perfect in whole RPM range and throotle range.
have not checked the plugs yet.
Project:
Project:
The following user(s) said Thank You: zed1015
- racerx311
25 Apr 2021 19:26 - 26 Apr 2021 04:20
Ride Report....... . Last year I installed Zed1015's Air Corrector jet kit and was really pleased with the improvement in drivability on my 1980 KZ1000. Over the winter, I sent my OEM Choke plungers to Zed1015 for service. The improvement is dramatic. The bike transitions from low to mid to top end flawlessly. I highly recommend his services/product.......
Last edit: 26 Apr 2021 04:20 by racerx311.
- zed1015
25 Jan 2022 13:30
Plungers to the rich and famous
Latest batch of refurbed choke plungers and air corrector jets all packed ready for their return trip to the New Zealand workshops of a certain Mr Crosby ( and it ain't Bing ).
- racerx311
25 Jan 2022 20:19 - 26 Feb 2026 07:43Congratulations Zed1015...This is a "major coup" for you. Mr Crosby does excellent Kawasaki Zed restoration .. And lets not forget his great racing career. Mr. Crosby will definitely like your product / service.....
Last edit: 26 Feb 2026 07:43 by KZQ.
- zed1015
26 Jan 2022 03:54 - 26 Jan 2022 04:01Yes! Always been a fan of Croz and it was a very pleasant surprise when i got his email .
Hopefully this "Major coup" might bring a bit more awareness to the plunger wear issue and lead to more than a set a week or so coming my way or maybe i should end my plunger repairing career on a high
Last edit: 26 Jan 2022 04:01 by zed1015.
- Pattenrd
20 Feb 2022 04:15
I sent a email on my Ebay account about purchasing jets for my kz 1000 stock vm28 carbs pleaselet me know what I need to do my email is pattenrd@yahoo.com thanks for your help
- zed1015
01 Jun 2022 00:33 - 01 Jun 2022 01:47
A little update to this thread because i'm unable to edit and add a pic to the first post..
A reminder to be aware that some VM26SS carb sets that are equipped with the FUEL mixture screws underneath are made up of all left or right handed carb bodies..
In this instance the jets must be installed in the air passage furthest away from the unmachined air screw boss.
In the case of left hand bodies ALL the jets should be fitted at the 4 o'clock position and on right handed bodies all at 8 o'clock..
See attached pic for example of a left hand body set with the jets installed in the 4 o'clock position..
Thanks.
Thanks.
Last edit: 01 Jun 2022 01:47 by zed1015.
01 Jun 2022 15:05
Thank you for the update. I’m concerned now. I just installed your corrector jets into a Suzuki set with both air and fuel pilots screws. Please look at included photo. Hopefully I got the right. Thank you.
