Machining crank
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
Machining crank
19 Oct 2006 03:16
#85383
Is it posible to cut the keyway longer on a 76 kz900 crank and re-drill the rotor bolt hole larger? I sheared the key on my rotor. The inside of the rotor is scored bad so Im getting another.The end of the crank has minor scores. So I want to machine the crank to hold the rotor better.What do you think?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wireman
  • wireman's Avatar
Re: Machining crank
19 Oct 2006 05:20
#85398
yep;)
