Starting noise Help
- BlackEyeCafe
Starting noise Help
05 Jul 2020 12:28
1977 KZ650C
DYNA ignition and coils
Fresh battery
New jets - 115 main and 17.5 pilot
Makes a noise when starting but won't turn over, not sure what I'm missing, please help.
Also overflowing on carb one
Fresh battery
1977 KZ650 C
Jets - Main 115 - Pilot 17.5 - Needles - Position 3 - NGK BR7ES
Re: Starting noise Help
05 Jul 2020 12:35
What sort of noise?
- BlackEyeCafe
05 Jul 2020 12:47 - 05 Jul 2020 13:10
Sorry tried to attach a video, here is a YouTube link
1977 KZ650 C
Last edit: 05 Jul 2020 13:10 by BlackEyeCafe.
05 Jul 2020 13:37
Sounds like your starter clutch mechanism need some attention.
- BlackEyeCafe
05 Jul 2020 13:45
It's funny, that's almost exactly the same thing my 8 year old said
1977 KZ650 C
05 Jul 2020 13:48
Smart kid.
- BlackEyeCafe
05 Jul 2020 13:52
You guys know if that's a rebuild situation or a new starter deal?
1977 KZ650 C
05 Jul 2020 14:24
- BlackEyeCafe
06 Jul 2020 07:17
Is it best to take it apart to see what is damaged first? Or is it obviously the starter clutch?
Also, i can only find repair kits on EBay containing 9,10, and 11. None i see contain 12 and 14. Do you have a good source for the parts?
1977 KZ650 C
- Warren3200gt
06 Jul 2020 10:05 - 06 Jul 2020 10:07
Dont get a repair kit or you will be doing it again in a few months. You need to buy a whole new starter unit. Available in the uk from zpower for about £110.00. If z1enterprises dont carry them zpower will ship if your in the US/Canada
Replacement involves work to both sides and dropping the sump. Its located in the heart of the engine but can be done from underneath with the engine in.
Last edit: 06 Jul 2020 10:07 by Warren3200gt.
The following user(s) said Thank You: KZB2 650
06 Jul 2020 10:57
KZrider members weeZee and Daftrusty do a ZR7 starter clutch conversion with more advance, stronger and cheaper used parts.
AFAIK Daftrusty did a six gear conversion too!!
kzrider.com/forum/2-engine/607684-kz650-...-part?start=0#777461
- KZB2 650
06 Jul 2020 11:15
Do a search....... lotta info and I agree with replacing the whole unit like Warren says and/or maybe Daftrusty's set up too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
The following user(s) said Thank You: Scirocco, Warren3200gt
