Help needed. 81 KZ650-D4 w 81 KZ750-4 (Wiensco 810 big bore) engine & VM24
  • gordone
  • gordone's Avatar Topic Author
29 Apr 2018 09:08 - 29 Apr 2018 09:17
#782592
I have a 81 KZ650-D4 with 81 KZ650-D4 and VM24 carbs.
4 to 1 exhaust and KM pod filters.
Main 112.5
Pilot 17.5
The needle high is one higher then middle (one step reache then middle).
Engine is rebuild, valve etc shall be according to speck.
Air/fuel (mix) screw is adjusted best I can and carb sync is done.
Today have I taken a longer trip and the bile is working fine in general, but I experience some load alternation approx +/- 50% throttle.
I think has nothing to-do with the RPM.
When I cruising with 10-20% RPM it goes perfect, and then I increase the throttle it response good, but when it comes to approx 50% it start to load alternation, not heavy like you need to-do something, but its should be better and you don`t have full propositional control over the throttle vs force.
These area is approx 10%, and I guess around 50% throttle, and if you crease further it disappear, but at the same time it disappear you feel more power also released.
And you have the proportional control back further 60-100% throttle.
The % is approx.
I can add one thing more, when you idle and if you are slow with the throttle you can kill the engine, if you are not so slow it goes okay.... just the second its picking up from idle when you give throttle are you really slow with the throttle it can die.. Don`t know of if these two thing are in relation?
Summary:
Good proportional / linear control 0-50%, 50-60% you have some prop. control, but you have load alternation more then I accept.and after maybe 50% it disappear and I have good prop. / linear control again.
When I was running with stock 750CC pistons, the bike was running fine, but I could feel the same load alternation, some times, in deep hills.
But it was fare softer and I was nothing doing anything with it. I`m running with the same jet setup now.
I have got a lot of help with my project and I have a other threat where I got help when it comes to start up procedure etc...
www.kzrider.com/forum/2-engine/607610-st...ter-rebuild?start=20
I just wanted to start a new threat for these specific problem, more information can be found there.
Nessism, have suggested jet issue?
KZB2 650, thing I`m close to the jet setting I shall have, rise the needle height one step?
I`m not in a hurry so just wanted to see if we all could agree on the next step :)
Project:
Last edit: 29 Apr 2018 09:17 by gordone.
  • KZB2 650
  • KZB2 650's Avatar
Re: Help needed. 81 KZ650-D4 w 81 KZ750-4 (Wiensco 810 big bore) engine & VM24
29 Apr 2018 13:39
#782606
The stock setting on 24mm carbs for a 650 is on the 4th clip (one clip from the bottom) with your set up I would think the bottom 5th clip one step richer (raising the needle) would be what you need. Like I said some riders have reported approx the same thing going on in the mid range and have blamed the pods over the air box but you should be able to get it 90% there.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • gordone
29 Apr 2018 14:56 - 29 Apr 2018 14:58
#782610
KZB2 650 wrote: The stock setting on 24mm carbs for a 650 is on the 4th clip (one clip from the bottom) with your set up I would think the bottom 5th clip one step richer (raising the needle) would be what you need. Like I said some riders have reported approx the same thing going on in the mid range and have blamed the pods over the air box but you should be able to get it 90% there.
Before the 810 upgrade when I was using the 750, it was much better so I assume we should be able to reach the same now also with 810.
Thank you,
I will try to change to clip 5 the next days and report back :)
Just curious, example if the size deviation for pilot and main jet was to big I would have the same issue? We are talking about the transfer perioed between the two jets?
Project:
Last edit: 29 Apr 2018 14:58 by gordone.
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Apr 2018 15:35 - 29 Apr 2018 15:35
#782613
I'd try one step up on the pilots.
Last edit: 29 Apr 2018 15:35 by SWest.
  • gordone
30 Apr 2018 00:44
#782637
SWest wrote: I'd try one step up on the pilots.
Since it had nothing todo with RPM, just throotle and in the mid range you think it’s the pilot?
I only have 20 pilot jet in spare and are running on 17.5 now. So I need to order 18, should I also order 18.5 just in case or?
What should I order to have something to play with?
Thank you.
Project:
  • gordone
30 Apr 2018 12:21
#782652
SWest and KZB2 650, what is the differences between increase the pilot jet and raise the needle?
Try to understand the advise from you both, since you KZB2 650 suggest raise needle and SWest, increase the pilot?
Thank you.
Project:
  • gordone
30 Apr 2018 12:40 - 30 Apr 2018 12:40
#782653
Some back and forth with me , sorry....
I have checked denniskirk.com and it looks like the next step is 20 (running 17.5 now).
So then I have pilot jets :)
Will try to install them soon and report back how it went.
Project:
Last edit: 30 Apr 2018 12:40 by gordone.
  • KZB2 650
  • KZB2 650's Avatar
30 Apr 2018 13:47
#782656
The pilot jets control idle and off idle to 1/8 th throttle or a little more....... the needle controls mid range ....... thinking Steve was refering to were you said it was a little off off idle dying on you and not responding quite right but 20s sound too rich to me .......
1978 KZ650 b-2
  • gordone
30 Apr 2018 14:01
#782659
KZB2 650 wrote: The pilot jets control idle and off idle to 1/8 th throttle or a little more....... the needle controls mid range ....... thinking Steve was refering to were you said it was a little off off idle dying on you and not responding quite right but 20s sound too rich to me .......
Ahh I understand, so try for improvement in the mid range is raise the needle as you had said before. Will try these the next days, and report back.
I have driven in the city for some hours today, and it`s annoying you need to give some throttle before you release the clutch if not you kill the engine.
You don`t have so smooth starts I had before with the original 750CC, maybe these has something to-do with higher compression also?
I understand it`s not much to-do with it then, if so must I try to gt 18 pilot jet or something? and not 20 because that is to large?
The biggest problem is the mid range so lets see what the needle raise give of effect, if that not helping, then I need larger carbs ?
Project:
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Apr 2018 15:23
#782663
Try the 20's. You can compensate with the air screws.
  • gordone
30 Apr 2018 15:27 - 30 Apr 2018 15:28
#782664
SWest wrote: Try the 20's. You can compensate with the air screws.
Increase pilot should improve off idle bevahior and raise needle should improve mid range?
Are you agree I should do both?
Is the best thing to test one thing at the time or shall install the 20 pilot jets and raise needle at ones?
Adjust the air/mix screw and do carb sync and then take it out for a spinn?
Thank you.
Project:
Last edit: 30 Apr 2018 15:28 by gordone.
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Apr 2018 15:33
#782665
One thing at a time. Install the jets then if you feel you need a little more at midrange, raise the needle one notch and bench sync. Each time adjust the air screws for best idle. Once you're satisfied, sync the carbs.
