Is this all i need to get 140hp
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Is this all i need to get 140hp
13 Jun 2017 07:09
#764239
obie83 wrote: It's definitely gonna be a street bike only no time on the drag strip. I figured with a 140hp I wouldn't be the last guy in my pack. But I don't want to break the bank either. So I figured about 3k max. I don't really want to deal with turbo's at all. The engine kit that I was talking about was the SSR1075
$1129.93
1075cc piston kit, K410 cams,
valve spring kit
I seen a lot of guys on the forum running these so I thought it was popular for a reason. It seems like I'm reaching past my expectations and budget
Ok Now we have a good starting point .
If that is the kit you want , go for it. Plus a valve job while the head is off and apart. .
What carbs do you have ?
What exhaust do you have ?
Are you doing your own labor other than machine work ?
That kit comes with wiseco pistons which are fine , but I prefer MTC Personal choice from experience with both..
10,5 to 1 compression is good for a street bike.
OR
Just do Piston kit and valve springs for now , add header and tune current carbs for now and do this in phases,
I have been tweaking my bike for almost 40 years , so dont be in a rush unless budget is no object
What kind of bikes are you riding with that you are concerned with not being last in the pack ?
Dave B) B) B) ,
The following user(s) said Thank You: Hardgun
  • obie83
  • obie83's Avatar Topic Author
13 Jun 2017 07:32
#764245
It just depends a couple of guys have V Rods, a few Suzuki m90's and some crotch rockets from 600 to 1k. I have never even ridden the kz1000 yet I brought it in pieces and figured I would just build it up instead of putting it together then tearing it back down. I also have a wrecked zx10 that I would be using for wheels forks and what ever else I could use on the kz
  • obie83
13 Jun 2017 07:34
#764246
I also Would-be doing all the labor myself except for the machining and the carbs are stock.
13 Jun 2017 07:52 - 13 Jun 2017 07:52
#764248
obie83 wrote: It just depends a couple of guys have V Rods, a few Suzuki m90's and some crotch rockets from 600 to 1k. I have never even ridden the kz1000 yet I brought it in pieces and figured I would just build it up instead of putting it together then tearing it back down. I also have a wrecked zx10 that I would be using for wheels forks and what ever else I could use on the kz
Gimme a break! In that case you can just tune the bike up to stock specs and save $3,000! If you are concerned about keeping up with a Suzuki M90 you can have a beer and relax. The M90 turns the 1/4 mile in 13.1 seconds (if the guy can ride it well) and has a top speed of 118 mph. The STOCK 1980 KZ1000 will run the 1/4 mile in 12.1 seconds with the same rider and has a top speed of 130 mph.
The only thing I would recommend is for you to buy a strong tow rope so you can tow the Sukuzi M90's behind you since that's the only way they will keep up with the KZ1000! Ed
Last edit: 13 Jun 2017 07:52 by 650ed.
  • TexasKZ
  • TexasKZ's Avatar
13 Jun 2017 13:50 - 14 Jun 2017 04:15
#764288
By the way, a stock ZRX1100 makes less than 100 hp, so you would be into a build there, too. The kit you mentioned is a proven combination that needs porting and bigger carbs to get best advantage of it.
For a purely street driven bike, I'd say the goal should be a really broad torque band. I wish I still had a copy of the Concours 1000 fsm. It has a dyno graph that is just what I mean. That engine has a torque plateau. More than 80% of max torque is available from about 3500 rpm to redline. Most street riding takes place at low to nid range rpm, and that is where the power should be focused. Going for really high horsepower near red line may sacrifice power in a more useful rpm range.
Be realistic about how you will ride it and get some expert advice about modifications that will get you best bang for the buck.
If you really want to hang with modern 1000cc sport bikes, fix your ZX10.
Last edit: 14 Jun 2017 04:15 by TexasKZ.
  • obie83
13 Jun 2017 14:21
#764294
Yeah the more I'm reading and thinking about it maybe 140 is reaching to far. Do you guy know what kind o numbers that 1075 with exhaust and aftermarket carbs would put down. What cams would you recommend for that bottom end power you were talking about
  • Moderator
  • Moderator
13 Jun 2017 14:34
#764296
obie83 wrote: Yeah the more I'm reading and thinking about it maybe 140 is reaching to far. Do you guy know what kind o numbers that 1075 with exhaust and aftermarket carbs would put down. What cams would you recommend for that bottom end power you were talking about
Frankly
Forget about the numbers and go for seat of the pants fun.
Get a 4 into 1 header , with a 1075 cc 10.5 to 1 compression piston kit and good valve springs and call it good
Use stock cams for now as they pull great down low.
Get your jetting right and a Dyna S ignition.
Then ride it for a season
Trust Us , It will be great
Then look at cams and porting the head and maybe different carbs later.
Install tapered steering neck bearings no matter what front end you use .
This is how all us hotrodders got our start
Dave B) B) B)
The following user(s) said Thank You: TheTrout, Nessism, obie83
  • kzdcw
  • kzdcw's Avatar
  • 77' KZ1000A
13 Jun 2017 15:54 - 13 Jun 2017 15:56
#764304
I think with the combination that zed1015 described, is probably worth a 25-30 HP gain over stock. But depending on head work and cam selection, a good "useable" combination for the street.
Get ahold of Larry !
77' KZ1000A
Last edit: 13 Jun 2017 15:56 by kzdcw.
  • TheTrout
  • TheTrout's Avatar
14 Jun 2017 05:09
#764342
Frankly
Dave B) B) B)
I did basically what you said above (minus the new pipe) with the same thinking that I could add the rest later.
What 4 into 1 header do you like? I was thinking V & H, but which one would give me more power? I believe the carbs on my model are 26mm and that will have to be handled at some point, but golly geepers a rack of nice carbs cost a lot!
1978 KZ1000B2
  • Moderator
  • Moderator
14 Jun 2017 05:53
#764346
Frankly
Dave B) B) B)
I went with the Yoshimura pipe , They are still offered but pricey. .
AS mentioned here and in other posts of mine building in stages is what I did.
Since I started with a new bike I did some things in different order.
First I replaced the 26mm carbs with 29 smoothbores which made me faster than my buds Z1R with 28s.
He put on Winning pipe / I did the Yoshi pipe to stay in front.
Then we both did 1075 wiseco kits and welded the cranks . ( anytime motors came apart we always installed new HD Cam chains.
From there we did 1200 big blocks and headwork and cams .
Then started over and went turbos as we both crewed on a top fuel bike and knew how to make these bikes fly
But no need for all this / or to do to much just to have fun
Dave B) B) B)
Bike in 1980
  • obie83
16 Jun 2017 11:39
#764532
Thanks for all the replies guys. It helped a lot
  • LarryC
  • LarryC's Avatar
18 Jun 2017 18:19
#764725
My advice to you would be to find a used ZRX1200 that hasn't been thrashed to death and buy it. That might seem like crazy advice from a guy that builds engines and ports heads but trust me, it's your easiest route to what you're goal is.
When someone contacts me about building a KZ motor, the first thing I tell them is that you have to understand one thing right from the start...."IT MAKES NO FINANCIAL SENSE WHAT SOEVER...YOU DO IT BECAUSE THAT IS THE BIKE YOU WANT AND YOU HAVE THE FINANCIAL RESOURCES TO DO IT CORRECTLY"
Consider that the vast majority of my customers are guys over 50 years of age. They are building their dream bike and have the resources to do everything, including suspension and cosmetics properly.
Just a week ago I sold my 99 ZRX1100 with 13000 miles on it for $2600. It could have used a fresh set of tires and a fork oil change but it also had a Dale Walker pipe, Factory Jet kit, braided lines and an under seat storage box that replaced the stock air box. You can really pack quite a bit under the seat. The bike was turn key....ready to ride.
As far as power it felt like my 1197 KZ custom I build back in 2008 with a good head, moderate cams and 36mm carbs. As far as midrange roll on, the KZ was probably a bit stronger there but up on top they felt really about the same.
I spent a great deal of time building the KZ and loved every minute of it. But it was a very big deal and it took many hours of hard work. The KZ custom got lots of attention everywhere I took it while the ZRX got far less. It's just a charisma thing....it was still a great bike.
A 140 honest real wheel HP KZ isn't going to happen with a 1075 motor and have the good street manners that a 110 HP motor would. The trade off isn't IMO worth it. You're going to have a minimum of $3500 to $4000 in the engine if you need carburetors and a pipe to go with the build. You're going to have an easy $3000 in the engine alone.
There's nothing quite as cool as a hot KZ all done up properly. It's not for every budget though and it takes time to do it right.
If your KZ is worth the money and effort to build, the hang on to it and do it properly as you get the money. In the meanwhile if you want to go ride with your buddies and not be left in the dust....go with something like a ZRX1200 that's ready to roll and enjoy our summer..
Larry C.
The following user(s) said Thank You: DOHC, TexasKZ, zukdave, obie83
