KZ440 LTD Possible Clutch Issue
  • BornAgainBiker
  • BornAgainBiker's Avatar Topic Author
14 Apr 2016 10:21
#720927
There is a rhythmic chirping/scraping noise while the bike is in gear and moving that seems to be coming from the clutch case area. The noise goes away if I pull the clutch lever in while driving.
There also seems to be a lot of clatter coming from the clutch case area at idle--this also goes away when I pull the clutch lever in.
It looks like I am going have to pull the clutch side engine case and take a look at the clutch basket. I was wondering what I should be looking for that might be causing the noise? :huh:
All the best, Jeff
1984 KZ440 D6
  • punisher11b
  • punisher11b's Avatar
Re: KZ440 LTD Possible Clutch Issue
14 Apr 2016 10:45 - 14 Apr 2016 10:47
#720933
Out of curiosity does it make a difference in sound depending on the rpm you are at while moving? The clutch on the 440 I have found to be a pain in the but to get set perfect although that could just be me :silly: . have you double checked the clutch adjustment ? Just so it can be ruled out.
- good luck
Last edit: 14 Apr 2016 10:47 by punisher11b.
  • BornAgainBiker
14 Apr 2016 10:59
#720935
The clutch adjustment is good, and oddly the sound seems to be related to bike speed rather than engine rpm. :huh:
All the best, Jeff
1984 KZ440 D6
  • punisher11b
14 Apr 2016 11:11
#720938
Hmmm, hope it's not a bearing going out. I might be mistaken but clutch basket issues are usually affected by RPMs . probably need to inspect to verify what the problem is.
- good luck
  • JR
  • JR's Avatar
14 Apr 2016 11:18 - 14 Apr 2016 12:44
#720939
Disregard
Last edit: 14 Apr 2016 12:44 by JR.
  • BornAgainBiker
14 Apr 2016 13:55
#720972
JR wrote: Disregard
JR do you mean just ignore it? Sounds good to me, but I just have to ask--what's the reasoning? :)
All the best, Jeff
1984 KZ440 D6
14 Apr 2016 14:04
#720974
If chain drive, would inspect chain for proper slack adjustment and assure it's properly lubed, and kink-free.
Good Fortune! :)
  • BornAgainBiker
14 Apr 2016 14:10
#720977
Thanks Patton, but it is a belt drive and everything looks good there. :)
All the best, Jeff
1984 KZ440 D6
  • JR
  • JR's Avatar
14 Apr 2016 17:13
#721000
BornAgainBiker wrote:
JR wrote: Disregard
ha ha
No dont disregard the noise
Sorry for the confusion BornAgain
I had suggested a tight chain and then edited my post and meant disregard my senior moment :laugh:
  • BornAgainBiker
14 Apr 2016 18:12 - 14 Apr 2016 18:13
#721007
JR wrote: Disregard
ha ha
I knew that sounded too easy. :) I just thought that you knew what it was and knew that it was nothing to worry about. Oh well, off comes the clutch case. :lol:
All the best, Jeff
1984 KZ440 D6
Last edit: 14 Apr 2016 18:13 by BornAgainBiker.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Apr 2016 18:34
#721016
I hate the not knowing. Best to have a look.
  • BornAgainBiker
15 Apr 2016 06:07
#721056
punisher11b wrote: Hmmm, hope it's not a bearing going out. I might be mistaken but clutch basket issues are usually affected by RPMs . probably need to inspect to verify what the problem is.
Good point, considering that the noise is related to bike speed, I think I'll start my search in the output shaft bearing area. :)
All the best, Jeff
1984 KZ440 D6
