Clutch rod
  • G-Force
  • G-Force's Avatar Topic Author
Clutch rod
25 Mar 2016 22:07
#717388
I have quick question. What does the clutch rod do and is it lubricated with engine oil. Thanka
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • TexasKZ
  • TexasKZ's Avatar
Re: Clutch rod
26 Mar 2016 06:14 - 26 Mar 2016 06:16
#717400
It disengages the clutch when the clutch lever is squeezed. It will get a little oil, hence the need for a seal.
As Swest suggests, a genuine factory service manual is important.
Last edit: 26 Mar 2016 06:16 by TexasKZ.
  • G-Force
Re: Clutch rod
26 Mar 2016 06:49
#717404
My clymers manual doesn't say much about it in the clutch section.the reason I asked is it feels gritty when Lrof it pushed in.Tried to flush with wd40 but still gritty.I thought if remove the clutch basket mabe can be cleaned from there.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Clutch rod
26 Mar 2016 06:52
#717405
Take off the sprocket cover and clean, grease the actuator.
Re: Clutch rod
26 Mar 2016 06:53 - 26 Mar 2016 07:04
#717406
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And the signature may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do.
Here's how:
For a free downloadable KZ750 4-cyl service manual, use this link, and scroll down to "The Bible" ---
mbsween.bike-night.com/kz750l3/index.html
Good Fortune! :)
Last edit: 26 Mar 2016 07:04 by Patton.
The following user(s) said Thank You: Little B
Re: Clutch rod
26 Mar 2016 07:05
#717407
Good Fortune! :)
Re: Clutch rod
26 Mar 2016 07:15
#717410
Good Fortune! :)
  • z1kzonly
  • z1kzonly's Avatar
Re: Clutch rod
26 Mar 2016 13:07 - 26 Mar 2016 13:10
#717448
Ya know when you beat the snot out of these bikes!
I have had the rod weld itself to the stock ball bearing behind the clutch basket and the OEM parts.
Hence the roller bearing fix they sell for the pusher
Last edit: 26 Mar 2016 13:10 by z1kzonly. Reason: file
The following user(s) said Thank You: KZB2 650
  • taildragger1197
  • taildragger1197's Avatar
Re: Clutch rod
26 Mar 2016 13:36
#717452
Sorry....I couldn't resist. :P
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
The following user(s) said Thank You: wrenchmonkey
  • TexasKZ
  • TexasKZ's Avatar
Re: Clutch rod
26 Mar 2016 13:50
#717456
You get a gritty feeling when squeezing the lever? If so, it is more likely the lever pivot, cable, and/or the actuator. Sometimes a great deal of chain lube and grit can cause the left end of the shaft to hang up on the seal.
Re: Clutch rod
26 Mar 2016 14:18
#717458
Neat inexpensive little gadget to quickly force lube throughout length of cable.
Good Fortune! :)
