How do I make my clutch pull easier?
- Mercury Kid
07 Apr 2012 23:07
Put heavy duty springs in my 1105 motor and they are a bear on the hand. Anybody have a good setup for the clutch perch and the actuator. I understand basic physics of leverage and such, just looking for somebody thats done this before.
'76 KZ900-Z1 clone
Z1 70's period longbike
- DiamondSkyBlue1000
Re: How do I make my clutch pull easier?
08 Apr 2012 00:36 - 08 Apr 2012 00:39
Last edit: 08 Apr 2012 00:39 by DiamondSkyBlue1000.
- T_Dub
08 Apr 2012 01:41
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- T_Dub
08 Apr 2012 01:43
But seriously, I have the APE kit which everyone says is brutal. I actually don't find it bad. Not sure why. I did take apart my clutch mechanism, cleaned and greased it. And I also have the thrust bearing pusher. I have a GP style lever too, maybe that makes some sort of difference which I doubt.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- les holt
08 Apr 2012 07:05
Light springs and a lock up clutch, your hands will thank you!
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
08 Apr 2012 10:50The best place to start, imo.T_Dub wrote: ...I did take apart my clutch mechanism, cleaned and greased it....
The actuator is accessed by removing the sprocket cover.
The actuator is attached to the interior side of the sprocket cover.
- T_Dub
08 Apr 2012 13:16Patton wrote:The best place to start, imo.T_Dub wrote: ...I did take apart my clutch mechanism, cleaned and greased it....
Yup it was a bit of a pain taking it all apart with all the tiny ball bearings, but with the amount of gunk built up in mine after 30 years I was glad I did. And like I said, APE clutch kit and its not hard to pull.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
08 Apr 2012 13:44 - 08 Apr 2012 13:53
Would suspect the clutch actuator at hand is the early screw type used on Z1 and KZ900, and probably dry and clogged with crusty old caked grease gunge.
Last edit: 08 Apr 2012 13:53 by Patton.
- Mercury Kid
08 Apr 2012 20:43
I already went through and greased the screw actuator and installed the APE roller pusher. The perch I have is zx600 to match the adjustable lever on the MC, not sure if I can change the lever to get better pull on the cable. Also thinking of lengthening the arm on the screw actuator to get more leverage.
Still getting the motor sorted but even after riding it for a couple minutes around the parking lot it was pretty tiring, and I'm not exactly a wuss haha.
Don't have the funds for the hydraulic kit, might try to piece one together from ZRX or GPZ bits.
'76 KZ900-Z1 clone
- StreetfighterKz
08 Apr 2012 21:39 - 08 Apr 2012 21:39Mercury Kid wrote: Don't have the funds for the hydraulic kit, might try to piece one together from ZRX or GPZ bits.
I put a kit together for my 1000 just to be different. I used a Zx7 M/C and slave cylinder and a clutch line from a VF750...I think.
I had pics on here with a small write up but I just searched and can't find anything.
I massages the stock engine cover with an angle grinder for the slave to fit inside. It's not the prettiest but it works very well.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 08 Apr 2012 21:39 by StreetfighterKz.
08 Apr 2012 23:58
If not already done, would assure the clutch cable is is well-lubed and in as-new condition. And routed in an easy loop without any kinking or sharp turns. And assure the push rod is straight and moving easily back and forth in its passage.
- TeK9iNe
- What did you do!?!
09 Apr 2012 00:43
Riding around in a parking lot having to constantly manipulate the clutch would suck on lots of bikes
When your oil is hot, theres no need to use the clutch to up or downshift on these bikes.
Try it -you'll thank me.
Remember, when upshifting back the throttle off quick then smooth it right back while you shift for a seemless upshift.
Downshifting is a bit more difficult. Put some pressure on the shifter peg, when your rpms come down, just bareley nudge the throttle up to a continuous cruise for that gear and shift with your foot.
You'll have it down in no time.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
