first time start and engine goes wide open!!!!
  • Francoisc27
  • Francoisc27's Avatar Topic Author
04 Jan 2012 21:34
#496360
I finally got my KZ started tonight and it went wide open...
what the heck would cause that to happen?
I did clean the carbs recently,
I am using an old gas tank with a tube going directly to the carbs.
I am bypassing all of the wiring that normally goes to the handlebars.
I checked the throttle lever and it seems to be in the idle position.
All the tubes and connections are tight (I dont tink there are any vacuum leaks)
what do you guys think?
1982 KZ1100
1982 KZ1100 a2
1983 kz1100
1981 kz1000
  • TexasKZ
  • TexasKZ's Avatar
Re: first time start and engine goes wide open!!!!
04 Jan 2012 22:02
#496365
1. Improperly installed or adjusted throttle cable.
2. Throttle cable hanging up.
3. Improperly adjusted idle screw.
4. It's actually a Toyota.
  • Flyndrive
  • Flyndrive's Avatar
04 Jan 2012 22:10
#496366
Toyota!!! Ha Ha lol
1980 KZ 550A1
1985 GPZ 900R
  • Francoisc27
04 Jan 2012 22:12
#496367
there is no throttle cable,
and the idle screw is turned all the way out....
and it's def not a toyota...LOL
1982 KZ1100 a2
1983 kz1100
1981 kz1000
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
04 Jan 2012 22:24 - 04 Jan 2012 22:28
#496375
Francoisc27 wrote: I finally got my KZ started tonight and it went wide open...
1982 KZ1100
What kind of old gas tank? Motorcycle tank with a shut off valve. Is gas leaking into the carburetor bore(s) when sitting (mis-adjusted float level, or leaking float valve)?. Look for gas in the bores after the bike has been sitting. Normally it is supposed go out of the overflow. But one could be clogged. How about the carb boots? Are there any air leaks, or the carbs not sitting flush against the boots? Or a boot folded in against the back of a carb? And so on. If the engine is getting fuel and air somehow even with the throttle is closed then I would think it could race. Not an expert on it. Never happened to me. But doesn't hurt to check these things out.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 04 Jan 2012 22:28 by KZJOE900.
  • JR
  • JR's Avatar
04 Jan 2012 22:48
#496382
Only time that happened to me bike started normally then idle just got faster and faster and faster until I realised I had not tightened properly the hose clamps on the carb boots (carb to engine hoses)
Perhaps check again ?
  • Francoisc27
04 Jan 2012 23:12
#496393
I got it.
Thanks guys for the help.
I didn't think to look past the diaphram to see the butterflies were half open.
It ended up being one of the hose clamps on the intake boot was holding the throttle stuck open.
what a sweet sound!!!! now if i can just find some pipes :)
and filters and brakes and hand throttle and a gas cap and ignition switch and clutch and
and and and,,,oh boy....
at least it runs...
1982 KZ1100 a2
1983 kz1100
1981 kz1000
  • Kitten Tooth
  • Kitten Tooth's Avatar
05 Jan 2012 03:31
#496446
hahaaa big KZ motors sound funny as hell without exhaust pipes bolted on :D
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
  • adrenalinrider
  • adrenalinrider's Avatar
05 Jan 2012 13:29
#496499
I took the tank off my 550 and used a lawnmower takn just to start when need needed since it;s in peices lolbut make sure u put a fuel filter between the tank and the carb:D
1st Bike 1981 Kz550A Pods,Mac 4 into 1, Stage 3 Dynojet kit
