low compression
  • 79kz1000*
  • 79kz1000*'s Avatar Topic Author
low compression
04 Jan 2012 19:22
#496326
well finally got a chance to look at the bike an c what's going on with the motor??? well low compression in all cylinders going like this 90,100,100,110,105. guess its time to tear bike back down after finally getting it together an finished this past June!!!!
79 kz 1000 ltd
76 kz 900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: low compression
04 Jan 2012 19:32
#496329
before u tare it apart . try to determine whether it is valves, rings or both. do a leak down test.
unless u just have a lot of miles on it and its time for a complete job , then carry on.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • etbike3135
  • etbike3135's Avatar
Re: low compression
04 Jan 2012 19:37
#496331
Ok, ill be the smartass. Do you have 5 cylinders?
1973 Kawasaki Z1
18 years in dragbikes
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: low compression
04 Jan 2012 19:46
#496336
etbike3135 wrote: Ok, ill be the smartass. Do you have 5 cylinders?
just rebuild the best ones. lol
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 79kz1000*
Re: low compression
04 Jan 2012 19:47
#496337
ops sorry bout that. im not actually sure how many miles the speedo says 20,000, but it suppose to have been redone an built sum.so i will do a leak down to c???
79 kz 1000 ltd
76 kz 900
  • etbike3135
Re: low compression
04 Jan 2012 19:56
#496339
Valve guides are the culprit on a lot of the early 900's. I just worked on a guys who had 90% leak down in one cylinder, right past the exhaust valve. He was still driving it too! You wouldn’t believe how blown out the guide was, could have almost stuck 2 valve stems down that hole.
1973 Kawasaki Z1
  • 79kz1000*
Re: low compression
04 Jan 2012 20:01 - 04 Jan 2012 20:12
#496340
that's pretty bad that would have to b the worst I've seen lol. i know im getting sum smoke out the pipe when i get on it. lost the big pull on the gas.
79 kz 1000 ltd
76 kz 900
Last edit: 04 Jan 2012 20:12 by 79kz1000*. Reason: forgot
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: low compression
04 Jan 2012 21:16
#496357
How are your valve clearances?
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: low compression
04 Jan 2012 23:10
#496392
79kz1000* wrote: well finally got a chance to look at the bike an c what's going on with the motor??? well low compression in all cylinders going like this 90,100,100,110,105. guess its time to tear bike back down after finally getting it together an finished this past June!!!!
Which bike are you referring to, the KZ900? Iff so the service limit on the compression is 85 according to the Z1-manual that I got off this site. With no more than a 14 lbs/sq in. from the highest to lowest reading. But my Clymer generalizes and says between 130 psi and 160 psi. And most people here quote the higher numbers. So I am unsure with this specific bike what the correct compression is. If you believe the manual below, then you are within service compression and don't need to rebuild. Hope someone here can clarify what is correct for your bike.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • 79kz1000*
Re: low compression
04 Jan 2012 23:37
#496398
it's the kz1000 ltd b3
79 kz 1000 ltd
76 kz 900
  • DoubleDub
  • DoubleDub's Avatar
Re: low compression
04 Jan 2012 23:40
#496399
Also depends on your compression gauge. Has been posted lately that the Harbor Freight compression gauges read low.
  • elfmagic17
  • elfmagic17's Avatar
Re: low compression
05 Jan 2012 00:39
#496416
Have you hade the cam chain off anytime? timing coud be off if it has. Make sure and I'd also check clearences too like Roy said while in there.
Kenny Hicks
74 Honda CB550
