seafoam
- gengomerpyle
seafoam
18 Dec 2011 22:03
if i was to put seafoam in my fuel tank what do i expect to happen, as in what will it clean?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- wireman
Re: seafoam
18 Dec 2011 22:28
everything it comes in contact with,my favorite carb cleaner.
- gengomerpyle
Re: seafoam
18 Dec 2011 22:30
that was the main thing i was wanting to use if for.
wireman wrote: everything it comes in contact with,my favorite carb cleaner.
1982 GPZ750R1 ELR
1971 Honda CB750K
1971 Honda CB750K
- wireman
Re: seafoam
18 Dec 2011 22:33
- Jeff.Saunders
Re: seafoam
18 Dec 2011 22:36
Seafoam can only clean if it can flow. When jets get clogged, it's not going to clear them.
Overall, I love Seafoam - I use it in a maintenance dose on all my motorcycles and lawn equipment.
Because it will clear carbon off valves and valve seats, it's a good idea to recheck valve clearances after running seafoam through the carbs and engine.
www.z1enterprises.com
Z1 Ent on Facebook,
- TeK9iNe
- What did you do!?!
Re: seafoam
18 Dec 2011 22:39 - 18 Dec 2011 22:40
Seafoam is ok. It works alot better in its concentrated form.
Instead of mixing it into the gas, try this:
Make sure to be in a very well ventilated area!
Turn off your petcock and remove the fuel line from the tank.
Insert a small funnel into the open fuel line.
Start the engine and pour the seafoam directly into the fuel line.
Continue topping up the line with seafoam until the engine begins to change rpm/stumble.
Rev the throttle good a few times - the bike will either rev or choke out - no matter. Stop engine.
Now the seafoam is well concentrated in there, cleaning everything up nicely.
Next day - drain carbs, reconnect fuel line, prime carbs and start as normal.
The engine will blow out some nasty exhaust at first, then your done.
Super clean.
Super clean.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 18 Dec 2011 22:40 by TeK9iNe.
- wireman
Re: seafoam
18 Dec 2011 22:40
dup the whole can in there,it'll be concentrated! :woohoo:
- MuzzleMike
- Rice Only
Re: seafoam
26 Dec 2011 05:25Jeff.Saunders wrote: Seafoam can only clean if it can flow. When jets get clogged, it's not going to clear them.
It will clean the valves . I am ordering shims for my 750 do to using it . It is good stuff!
82 KZ750 LTD H3
- Roca
Re: seafoam
08 Mar 2012 18:37
I was just wondering the same thing about seafoam. Can u use it as a fuel/ oil additive between changes or is it just for flushing out?
1980 KZ550-C2 LTD Custom
- mark1122
- Keep twisting it
Re: seafoam
08 Mar 2012 18:47
u can add it to the oil, just read the can. u put it in oil, ride x miles then change.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Re: seafoam
08 Mar 2012 18:55
I've never put it in my oil; I don't know if it would do bad things to the clutch. I use in in my fuel once each Spring and each Autumn. Just be sure to follow the instructions on the can - I believe it's 1 ounce of Seafoam for each gallon of fuel. Some folks have overdone it and their bike runs very poorly until they burn it. (Like 1 guy who added a whole can to 1/2 gallon of fuel - waaay too much). Ed
- TeK9iNe
Re: seafoam
08 Mar 2012 23:11
Yeah, read te instructions carefully. You use it right before and oil change, you dont run around with it in there for any length of time.
As far as in the gas, Eds' right. It can be mixed fairly strong, but it will make noticable smoke and reduce power till its gone. Best to run by the instructions - or a whole can to an entire tank of fuel at the most.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
