searching for piston rings
- z900750sei
25 Nov 2011 16:28
[attachment:3]C:\fakepath\PICT0053.JPG[/attachment]
Hello, I'm new here and I need help. I bought Z1A in bad shape and I'm restoring it. When I dismantled engine I realize that pistons are 72,00mm . Now I need piston rings but I don't know thw manufacturer of the piston . Inside wrotes SK. Please tell me where can I order piston ring and head gasket for this pistons
regards
Simon, Slovenija
regards
Simon, Slovenija
Kawa Z1, Kawa Z1A, Kawa H1D 500, Rickman CR 900, Benelli 750 sei 1976, Kawa KZ 1300 1979, Kawa Z1000H fuel injection, Kawa Z1000J replica of ELR, Moto Martin KJ 1000, Kawa KE 175, Bimota Mantra 2001, Benelli tornado tre 900 2004, Kawa ZZR 1400 2008 and project Kawasta.
- mtbspeedfreak
Re: searching for piston rings
25 Nov 2011 16:57
If you need new rings made, check out Hastings Manufacturing:
www.hastingsmfg.com/
2000 ZRX 1100
1976 KZ 900- Daily Driver
- z900750sei
25 Nov 2011 17:04 - 25 Nov 2011 19:08
Hastings says select manufacturer, but I don't know manufacturer.
Last edit: 25 Nov 2011 19:08 by z900750sei.
25 Nov 2011 17:47 - 25 Nov 2011 17:50z900750sei wrote: [attachment:3]C:\fakepath\PICT0053.JPG[/attachment]
regards
Simon, Slovenija
Other members will have better and more definite advice.
Could contact Z1 Enterprises
www.z1enterprises.com/site-guide.aspx
to ask whether these rings should fit
www.z1enterprises.com/Ring-Set--72mm-XC-...900-KZ1000-4172.aspx
Am wondering if replacing the rings is enough for an engine in bad shape.
Last edit: 25 Nov 2011 17:50 by Patton.
- z900750sei
25 Nov 2011 19:13
On one cylinder I will have to change sleeve, but pistons , head camshaft are O.K. Bike was in bad shape but now is allmost restored except engine. I have attach fotos of piston.
- Motor Head
25 Nov 2011 23:22
Along with the Diameter, the thickness of the rings, both compression and the oil ring. That will be whats needed. They just might be stock pistons from the photo's.
- APE Jay
26 Nov 2011 01:37
Those old fat 72mm rings might be Honda GL1000 Goldwing
- mark1122
- Keep twisting it
26 Nov 2011 09:30
just phone Hastings and give them the dimentions. they will help u out. they are very good to deal with. they will need the diam, (72mm), and the thickness, and width.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- z900750sei
27 Nov 2011 15:35
thank you very much
