A Couple More Dumb Questions
  • PaulyWally
  • PaulyWally's Avatar Topic Author
  • Total Bike Newbie
31 Oct 2011 11:47 - 31 Oct 2011 11:48
#486247
In the torque settings table of my service manual, what do these two numbers mean (see attached pic)?
Attachment Screenshot.png not found
The table also lists a locking agent for some bolts. What locking agent do you all recommend?
On engine covers that aren't listed in the torque setting table, is there a recommended min-max torque I should aim for? For example, the transmission cover isn't listed in the table. And in the installation section, it just says to "tighten the screws".
1976 KZ750 Twin
Last edit: 31 Oct 2011 11:48 by PaulyWally.
  • P21
  • P21's Avatar
Re: A Couple More Dumb Questions
31 Oct 2011 12:12 - 31 Oct 2011 12:13
#486249
i think it is size and Pitch (thread) of bolt
Kawasaki KZ 1000 Police (2002) P21
Last edit: 31 Oct 2011 12:13 by P21.
  • loudhvx
  • loudhvx's Avatar
31 Oct 2011 12:16
#486250
The 6 appears to mean the bolt's shaft diameter in mm.
The P number is the thread distance. Distance from one thread to the next. (It's the reciprocal of pitch in mm.)
6 P1.0 is a 6mm bolt with 1mm threads (1.0 thread per mm). In the U.S. it would proabbly be called an M6 x 1.
8 P1.25 is an 8mm bolt with 1.25mm threads (0.8 threads per mm). M8 x 1.25
Lengths of the bolts are not indicated, from what I can see.
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
31 Oct 2011 12:18
#486252
P21 wrote: i think it is size and Pitch (thread) of bolt
+1
The first number would be the size in mm, and the second is the thread pitch. So the one you have circled is an M6 x 1.0 thread bolt :)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • P21
  • P21's Avatar
31 Oct 2011 12:31
#486255
Attachment neverseez.jpg not found
also about thread locking agents
use Loc-tite (blue only)
and other bolts that need removed later i use (anti-seize lube)
this is very old can i have i also have the newer stuff i just like the old school can
and also never a dump questions
  • clutch
  • clutch's Avatar
31 Oct 2011 12:36
#486256
And that wasn't a dumb question either ;)
Wish List:
  • MFolks
  • MFolks's Avatar
31 Oct 2011 15:27
#486304
Thread Locking Compounds
Loctite #222MS PURPLE, low strength thread locker
For screws under ¼”.
Loctite #242 BLUE, Medium strength thread locker
For ¼” to ¾” bolts.
Permatex # 24310 Low strength thread locker, PURPLE, fasteners under ¼” diameter.
Permatex # 22210 Medium/high strength thread locker, BLUE, ¼” to ¾” fasteners, surface insensitive (can be used on oily fasteners).
Permatex # 24210 Medium strength thread locker, BLUE, ¼” to ¾” fasteners.
  • clutch
  • clutch's Avatar
31 Oct 2011 15:51
#486309
MFolks wrote: Thread Locking Compounds
For ¼” to ¾” bolts.
+1 !!!! I'm not a fan of permatex brand right now (see my recent posts), but I do love me some blue locktite! Good stuff :)
Wish List:
31 Oct 2011 16:24
#486313
www.google.com/products/catalog?hl=en&su...qi=2&ved=0CFQQ8wIwBA
Permatex claims this thread sealant may be used on "fuel fittings," but the ad doesn't expressly mention gasoline or gasahol or ethanol.
Would most likely not be suitable for sealing the adapter plate against the fuel tank.
Good Fortune! :)
  • PaulyWally
  • Total Bike Newbie
02 Nov 2011 01:03
#486649
Wow! Lots of great info. Thanks!!
What about this?
PaulyWally wrote: In the torque settings table of my service manual, what do these two numbers mean (see attached pic)?
1976 KZ750 Twin
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Nov 2011 05:35
#486660
Your bike originally came with phillips-screws holding the engine covers to the cases. Actually, technically, they were JIS (Japanese Industrial Standard) screw heads and are slightly different than phillips-heads...which is why they tend to 'round-out' with use. The tips of a JIS and Phillips screwdrivers are shaped differently.
It is difficult to torque a screw (no comments from the peanut gallery, please) to a particular specification. A common upgrade over the years was to replace those screws with allen-head bolts. I tighten those by hand until they feel 'tight'...sorry, can't be more specific then that.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • PaulyWally
  • Total Bike Newbie
02 Nov 2011 09:34
#486676
Mcdroid wrote: It is difficult to torque a screw (no comments from the peanut gallery, please) to a particular specification. A common upgrade over the years was to replace those screws with allen-head bolts. I tighten those by hand until they feel 'tight'...sorry, can't be more specific then that.
Cool.
I am also changing them all out to allen heads. I figured I could torque 'em using a hex bit adapter on my torque wrench (should be much easier to torque than the original 'phillips'). I was just afraid of over-tightening and stripping the aluminum threads. But if that's really not needed... [shrug]
1976 KZ750 Twin
