Opposite problem with revs......
  • cole
  • cole's Avatar Topic Author
28 Oct 2011 06:26
#485752
Hey guys.
I have a 1982 KZ750E2 bobber that sounds like it is revving the hell out of itself!
It has no rev counter, but at 50mph, it sounds as though I am riding at 100mph!
Is that right? Can't find any guides on mph/rpm online.
TIA,
Mark
"Ride it like ya stole it!"
Re: Opposite problem with revs......
28 Oct 2011 08:59 - 28 Oct 2011 09:00
#485757
Sounds like your clutch is slipping. It would be much easier to diagnose if you had a tach.
Last edit: 28 Oct 2011 09:00 by 650ed.
  • H1Vindicator
  • H1Vindicator's Avatar
28 Oct 2011 09:13 - 22 Jan 2013 00:54
#485758
Last edit: 22 Jan 2013 00:54 by H1Vindicator.
  • Motor Head
  • Motor Head's Avatar
28 Oct 2011 09:42 - 29 Oct 2011 13:01
#485766
Only 5 minutes to check that your clutch push rod has free play, and is adjusted properly. Might be all it is, or the clutch could need rebuilding.
Whats your sprocket sizes? Still have the Tach you removed to Bobb the KZ?
Last edit: 29 Oct 2011 13:01 by Motor Head.
  • cole
29 Oct 2011 10:41
#485882
Thanks for the replies so far..........
Complete engine/clutch rebuild less than 100 miles ago (3 weeks), but the bike sounded exactly the same as before the rebuild. (I didn't bob it, but thats the reason I DID buy it!)
Everything has been adjusted and checked twice before a roadtest on the rebuild.
As for the sprocket teeth, that is a job I will have to do tomorrow....Count the teeth and see what I've got there.
Am I correct in thinking that the smaller the rear sprocket, the lower the revs?
I'd love to have a tachometer but just cannot find one anywhere!
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
29 Oct 2011 10:49
#485885
Whats your exhaust look like... baffled?
These bikes are pretty loud and screamy when theyre only halfway to redline.
Smaller rear sprocket = lower rpm for given speed, yes.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • MFolks
  • MFolks's Avatar
29 Oct 2011 15:43
#485928
What type and grade of engine oil being used? The wet plate clutch and starter clutch will slip if oils meant for cars is used in them.
Best Oils To Use In Your Bike (Just My Opinion)
Engine oil : The commercial grade oils are clearly superior to the mass market oils. For the best protection in your bike or car, use Shell Rotella Synthetic, available at Wal-Mart in blue containers . For the best petroleum oil you can buy, get Shell Rotella T, Mobil Delvac 1300, or Chevron Delo 400, available at any auto parts store. On the back of most oil cans is a circular stamp with the certification.
Avoid oils that say "energy conserving" in the bottom half of the donut. These oils contain friction modifier additives that could cause clutch slipping over time. The EPA mandated certain gas mileage, so the auto makers turned to the oil manufacturers who came up with friction modifiers in the oil to meet these new standards. All XXw-20 and XXw-30 oils are energy conserving, and should not be used in your motorcycle. Don't buy any oil additives like STP or Slick-50. Here's several listings on all about oil justifying these conclusions.
The Recommended Synthetic Oils :
5w-40 Delvac 1 Synthetic
5w-40 Mobil-1 SUV/Truck Synthetic
5w-40 AMSOil AMF Synthetic (pricey, but it’s your money)
10w-40 Golden Spectro Synthetic
10w-50 Motul 5100 Synthetic
10w-40 Mobil-1 Synthetic
15w-50 Mobil-1 MX4T Synthetic
The best synthetics are: (in no particular order)
Shell Rotella-T Synthetic 5w-40 (blue container is synthetic, not white which is dino), gallon at Wal-Mart.
Mobil Delvac-1 5w-40 (grey container is synthetic, not black which is dino), gallon at Petro stations, gallon at Farm and Fleet.
Mobil-1 SUV 5w-40, qt anywhere.
AMSOil AMF 10w-40 synthetic motorcycle oil. (again, pricey)
Golden Spectro Supreme, (no price).
Motul 5100 Ester, (no price).
Mobil-1 automotive oils all contain small amounts of moly - about 100 to 200 ppm. This can cause clutch slippage in some motorcycles. I've only heard of this being a problem in Honda Shadows.
The Recommended Petroleum Oils
Chevron Delo 400 15w-40
Delvac 1300 15w-40
Shell Rotella 15w-40
The best petroleum oils are: (in no particular order)
Chevron Delo 400 15w-40 (blue container) gallon at any auto parts store, gallons at Costco.
Mobil Delvac 1300 15w-40 (black container) gallon at any auto parts store, gallons at Sam's Club.
Shell Rotella-T 15w-40 (white container) gallon at Wal-Mart or any auto parts store, gallons at Sam's Club.
Castrol 15w-40 (Green container) gallon at Wal-Mart or any auto parts store, gallons at Sam’s club.
