Ape cylinder studs
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
Ape cylinder studs
21 Sep 2011 08:49 - 30 Sep 2011 15:17
#478234
I followed a couple people's suggestion to change out the stock cylinder studs on my 1100 engine for Ape studs and head nuts. Doing this has essentially eliminated my concern of oil leaks re-developing at the head gasket.
Something to note*...the Ape stud (shaft body) is larger in diameter than stock, which necessitates slightly enlarging the notches of the head gasket(s) to fit properly around them; just at the two central cylinder studs on each side of the cam-chain.
:cheer:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 30 Sep 2011 15:17 by daveo.
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Ape cylinder studs
21 Sep 2011 09:01
#478236
I used the same set up on my 900 build... Measured OEM stud heights off decking pre removing...
Came out same lengths when completed and didn't have to notch at all...
What KZ model is yours?
Hmmm, wondering the differences in the head, good to know for the 78 KZ1000 build out...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
21 Sep 2011 09:19 - 21 Sep 2011 09:21
#478237
daveo wrote: I followed a couple people's suggestion to change out the stock cylinder studs on my 1100 engine for Ape studs and head nuts. Doing this has essentially eliminated my concern of oil leaks re-developing at the head gasket. Something to note*...the Ape studs are larger diameter than stock, which necessitates enlarging the notches on the head gasket(s) for them to fit properly.
:cheer:
and they require more torque when tightening
Last edit: 21 Sep 2011 09:21 by jonnybravo.
  • T_Dub
  • T_Dub's Avatar
21 Sep 2011 09:23
#478239
Wiseco head gaskets fit over KZ650 APE studs just fine :evil:
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • daveo
  • Premium Member
  • Premium Member
21 Sep 2011 11:30 - 21 Sep 2011 11:41
#478284
The bike is an 82' KZ1100A-2. The APE stud shafts are larger diameter than the stock ones. Not a lot, but enough that the head gaskets don't fit around the center-most studs, without making the two notches larger...with OEM (Kawasaki) gaskets, anyway.
Last edit: 21 Sep 2011 11:41 by daveo.
  • Observer
  • Observer's Avatar
23 Sep 2011 11:39
#478969
Will the Ape studs fit a 1982 KZ1000 LTD? Sick of the constant
oil weeping
  • APE Jay
  • APE Jay's Avatar
23 Sep 2011 13:21
#478990
Yes they will. CS900K fith all big fours from Z1900 thru GPZ1100s
ape-store.com/shopsite/page20.html
  • Observer
  • Observer's Avatar
23 Sep 2011 20:57
#479059
Thanks very much
  • DFIGPZ
  • DFIGPZ's Avatar
25 Sep 2011 10:42
#479392
There is no reason they should not fit over studs as the largest part of the stud is where the head not threads on which is the same on the APE stud as the the stock stud.
1984 750 Turbo
  • jonnybravo
  • Banned
  • Banned
25 Sep 2011 19:15
#479482
Observer wrote: Will the Ape studs fit a 1982 KZ1000 LTD? Sick of the constant
oil weeping
why does stud size cause oil weeping ??? answer ... it shouldnt look for other causes
  • APE Jay
  • APE Jay's Avatar
25 Sep 2011 22:51
#479551
Because you can't pull the oem studs down and have them stay tight enough.
  • jonnybravo
  • Banned
  • Banned
26 Sep 2011 04:19
#479599
APE Jay wrote: Because you can't pull the oem studs down and have them stay tight enough.
so everyone with OEM studs (like me) should have weeping then ??? :whistle: :whistle:
