Engine Vibration
- aek
Engine Vibration
21 Sep 2011 04:22
Hi folks! Newbie here and with a problem. Bike is a '80 750-4 LTD with 38000 miles on it. It was largely stored for the last 15 years but I have it out now and for the most part am getting it in pretty good order except for a motor vibration. It comes on at 4100 RPM's and stays. It goes from dead smooth to a buzzy harmonic type vibration always at the same engine speed and is the same on the road or the stand with the clutch in. Anyone know where to start? I'll appreciate any help!
Art
Art
1980 750-4 LTD original owner
- daveo
Re: Engine Vibration
21 Sep 2011 08:28
Not sure if this will help, but...my 82 1100 had a similar vibration this summer, and it took a while to figure out that the stock exhaust system was vibrating, even though it was fastened down tight. I loosened the center clamp, and pulled the two pipe sections together while re-tightening. That took care of the problem with mine.
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: aek
21 Sep 2011 08:38
Have always used a little rubber "motor mount" to isolate exhaust vibration from the frame.
- aek
22 Sep 2011 02:52
Thanks for your response. I don't think it's the exhaust but it's SOMETHING and the exhaust is handier than anything else so I'll start there! I think it's past time to gain a better understanding of the inside of the engine/transmission so a repair manual is a priority now as well.
Art
Art
- JR
22 Sep 2011 22:48
If I dont have my gastank on properly mine will vibrate and make noise. For example if the back end - where the tank meets the seat - is just touching the frame it will do that. Drove me nuts the first time it happened. Try running the motor and when you get the vibration see if pushing the gas tank has an effect.
23 Sep 2011 10:36 - 23 Sep 2011 10:37
Perhaps motor mounts need re-torquing.
If not already done, a good tune-up sometimes minimizes engine vibration.
This includes assuring that all valve clearances are within specs.
And cam chain adjustment, if applicable (per FSM).
Would also perform a compression test.
Last edit: 23 Sep 2011 10:37 by Patton.
- aek
28 Sep 2011 02:19
I didn't really want to run the valves but your comments sounded right and they were. First I ran another compression test and discovered one cylinder had dropped 30 psi. That made running the valves an easy decision. Found clearances from .0015 to .004 except no. 3 cylinder which had no measurable clearance at all on the intake. I swapped shims, reinstalled the camshaft and the compression went up and in fact matches the other 3 cylinders. I think I'm pretty lucky! These are running 125 cold w/o any throttle at cranking speed. I feel this is OK - do you agree? At this point I plan to change some shims to get out to .006 or so and put the cover back on. Yes/No?
This engine had a Kawasaki upgraded tensioner installed some time back and it seems to be working correctly. Engine uses the later cam chain and visually it looks good also. I found the front upper engine mount bolts were a little slack and tightened. Now will it still vibrate when I get it back together? I hope not but am not really sure Ive found the source.
Thank you for your guidance so far.
Art
Art
