Vance & Hines pipes
- KZ1000LTDPENNSYLVANIA
Vance & Hines pipes
07 Sep 2011 14:09
My 1979 KZ1000 LTD came with Vance & Hines 4 into 1 pipes on it. I can't seem to find any date on what it does for the performance. Increase in HP, etc. Does anyone know what it might be?
Thx
Thx
1979 KZ1000 LTD
- Mcdroid
- Gone Kwackers
Re: Vance & Hines pipes
07 Sep 2011 14:22
Well...not to be flippant...but 4into1 pipes alone only make you sound faster. Actual increases in HP are negligible...real, but negligible. Substantive increases in HP requires changes in carbs and motor work.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
07 Sep 2011 14:45
No problem Michael. Actually, I have the stock pipes and may put them back on because the bike has all the power I need and then some. I'm planning on just puttering around.
Thanks for the info!
1979 KZ1000 LTD
- Mcdroid
- Gone Kwackers
07 Sep 2011 14:55KZ1000LTDPENNSYLVANIA wrote: No problem Michael. Actually, I have the stock pipes and may put them back on because the bike has all the power I need and then some. I'm planning on just puttering around.
If you have the stock airbox in place, return to the stock exhaust system and your bike will run it's absolute best.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: KZ1000LTDPENNSYLVANIA
07 Sep 2011 15:20
Would be interesting to know the weight difference between the stock system and the V&H 4>1.
07 Sep 2011 15:48
Yes it would be interesting to know. If I do switch the pipes, I will try and remember to weigh each set when they are off the bike.
1979 KZ1000 LTD
