normal operating temp
  • 79kz1000*
  • 79kz1000*'s Avatar Topic Author
25 Jul 2011 21:52
#464909
Was wonder what would be a normal operating temp be for a 79 kz1000 ltd b3? Thanks for any help
79 kz 1000 ltd
76 kz 900
  • steell
  • steell's Avatar
Re: normal operating temp
25 Jul 2011 22:29
#464916
Normal operating temp measured where?
Oil temp? Depends on local air temp, rpm and load on motor, wind direction, etc.
On a 750 four we measured a pretty consistent 400 degrees on the head near the exhaust ports, temps dropped as we proceeded to the rear of the motor.
  • TexasKZ
  • TexasKZ's Avatar
25 Jul 2011 22:35
#464917
There have been a couple of pretty long threads about this. Try searching under oil cooler or oil temp
  • 79kz1000*
25 Jul 2011 22:40
#464920
On the head I took the bike for a ride down the road it was 110 and after about 3.5 miles it was feelin hot so I put a inferred temp gauge and it was 275 on top of head below valve cover
79 kz 1000 ltd
76 kz 900
  • MFolks
  • MFolks's Avatar
25 Jul 2011 23:09
#464932
The engine & oil need to get hot enough to boil the water formed due to normal combustion out of the motorcycle. Short trips will need frequent oil changes, if the engine does not get up to at least 212 F (the boiling temperature of water in an unpressurized condition).
