flywheel puller
- Goalieguy35
- JJ
flywheel puller
17 Jul 2011 18:36
Hello, i need to remove my fly wheel from the 1980 z1000 motor and i bought a 18mm one that was suggested to fit but it does not. Does any one know the correct size of the external sizes. and also the size of a 1976 kz900 motor. i need to do a flywheel swap and the thread sizes are different.
Thanks
Thanks
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
- roy-b-boy-b
Re: flywheel puller
17 Jul 2011 21:31
The large pinch bolt from the front end forks will remove the old style flywheel.
On my newer style fly wheel I use rear axle or a swingarm pivot bolt. I forget which it is. Roy
Re: flywheel puller
17 Jul 2011 21:44
In the strictest sense, these engines do not have a flywheel. At one end of the crank is the ignition triggering system (points or electronic), at the other end is the alternator rotor. Like Roy b said, the rear axle will work as a puller on later models, though problems can ensue. Are you absolutely sure that that 900 rotor will fit your 1000 engine?
- Goalieguy35
- JJ
Re: flywheel puller
17 Jul 2011 22:52
Im not entirely sure yet. I swapped all the ignition, that fitted right in. If the 1000 rotor doesnt fit i will get the correct one. But i was pretty sure the only different between the 900's and 1000's was a punched out head, and caming was different.
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
- otakar
Re: flywheel puller
17 Jul 2011 22:55 - 17 Jul 2011 22:56
The "J" motors are 18x1.5mm and older motors are 16x1.5. Some of the shaft bikes have a left hand thread 18x1.5mm If you have a 1980 than it should be 16x1.5mm
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 17 Jul 2011 22:56 by otakar.
- andy9802gt
- If it tastes that good, eat it yourself.
Re: flywheel puller
17 Jul 2011 22:59
I think the rotors and crank changed mid '78. The early cranks had a small end and taper fit on the rotor and the late cranks had a bigger end and a woddruff key to secure the rotor from spinning. I also believe that the rotors are completely different on the '80's and up. I could be wrong but I don't think it will work.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- otakar
Re: flywheel puller
17 Jul 2011 23:06
The MK-II motors went to the 20A alternator from the earlier 12A. But regardless, it will be either a 16 or 18mm puller
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Goalieguy35
- JJ
Re: flywheel puller
18 Jul 2011 01:25
ok thanks everyone for the help! appreciate it.
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
Re: flywheel puller
18 Jul 2011 09:52
This link from Z1E includes some flywheel pullers.
www.z1enterprises.com/SearchResult.aspx?...True&KeyWords=puller
