Shifter linkage. (new rearsets)
  • Cruez
  • Cruez's Avatar Topic Author
14 Jul 2011 14:02
#462827
Trying to workout my new shift linkage with some rearsets.. Does anyone know what bikes have the same diameter/spline count for the shifter rod? I've tried searching but can't find any specifics. Who else has changed out their rearsets and found a solutions?
Thanks
Ryan
  • TexasKZ
  • TexasKZ's Avatar
Re: Shifter linkage. (new rearsets)
14 Jul 2011 14:44
#462832
You could just saw off the stock shift lever, leaving a long enough stub to drill a hole for a Heim joint.
  • hocbj23
  • hocbj23's Avatar
14 Jul 2011 14:52
#462835
KZ1300 shifter will fit--same spline count but shorter rod.I am using one as a "rearset" on my KZ cause my boot toe kept hitting the cases.bj
  • steell
  • steell's Avatar
14 Jul 2011 19:38 - 14 Jul 2011 19:39
#462882
I don't know what kind of bike you have (mind reading app is unavailable at the moment), but I think all the KZs from at least the 650 through the 1100 share the same splines, I know for a fact that the 83-85 GPz750 and Turbo shifter will fit on the 750 twin, and the 750 twin shift lever will fit the 650/750/900/1000 motors.
Last edit: 14 Jul 2011 19:39 by steell.
