Smog device leaking oil...?
- apbling
14 Jun 2011 11:47 - 14 Jun 2011 11:48
1980 750-4 LTD.
On my daily commute (44 miles, 60 mph) the other day I noticed I had some streaks on my airbox. I followed it back to the cam cover. The gasket is shot and a new one is on order, but I noticed I have a second source of the seepage...the smog device. It's coming from the rubber thing that sits between the coils (between the vacuum switch and airbox). It's seeping out of the connection. Now, the oil appears to be coming from the reed valves, not from the airbox. I figured this because the line from the airbox is dry (as is the airbox and filter). Has anyone else had this issue? I know last time I was in there the reed valves were a bit oily and carboned up. The bike doesn't use any oil (that I can notice by smell/color or oil level).
I left the smog device there because it wasn't causing any issues, but I think I'm going to do away with it now, but was curious if this is the symptom of maybe a larger problem.
BTW, stock intake, valve clearances good, APE cam chain tensioner, 145ish PSI on all cylinders, correct oil level and runs great.
Last edit: 14 Jun 2011 11:48 by apbling.
- ELCouz
Re: Smog device leaking oil...?
26 Jun 2011 16:40 - 26 Jun 2011 16:40
Get a valve cover which has the exhaust auxiliary port blocked. I think Canadian version of the KZ doesn't have this!
By looking on ebay they look rare! Ironically all my KZ engines i had in the past never had this system :blink:
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 26 Jun 2011 16:40 by ELCouz.
- apbling
26 Jun 2011 23:16
That would be nice. I just took it all out and JB welded it. Well, actually the store was out of JB Weld, so I bought the knockoff. Must not be as good of stuff because it gets soft at engine temps. I'll have to drill it out and re-do it.
- JR
27 Jun 2011 18:05
Or just run a hose from one side of the valve cover to the other and remove the other end from the carbs or airbox or wherever they went and plug the holes. Glad we never saw that mod up here.
- apbling
27 Jun 2011 18:11
Yeah, I might just do that... that will look better than having than having nothing on it.
27 Jun 2011 18:15 - 27 Jun 2011 18:16Attachment airinjectepavalvecover.jpg not found
Last edit: 27 Jun 2011 18:16 by Patton.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
27 Jun 2011 19:09
Here is what I did that was to be a temporary fix until I got some CNC'd block-off plates (still need to just keep forgetting for something like 3 years now! :pinch:
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- JR
27 Jun 2011 21:14
Wow !
I was so dazzled by the awesome motor that it was minute or two before I noticed the cool hose on the valvecover :woohoo:
- KZ_Rage
27 Jun 2011 21:23
The wife couldn't understand why I wanted so many photos of it, "like the smell of gas and oil it's a guy thing" I told her! :laugh:
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
- apbling
28 Jun 2011 12:38
Where could one get a cool looking hose like that?
- loudhvx
28 Jun 2011 13:01
There are also various block-off plates that replace the ones with the ports. Even though they look real close, the 550 ones are slightly smaller than the 750 ones (in case you were wondering
Ape makes block-offs for the 550, but not sure of the 750.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- KZ_Rage
28 Jun 2011 16:28
It's just a temporary thing that has went on too long, I got that stuff from a Parker Hose & Fitting Store.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
1984 KZ550F2 SOLD!
