windage tray?? undercut trans
- 771000KZ
06 May 2011 22:02
Hey guys, if you've read my other posts you would know I got a free mark 2 engine from a guy cleaning out his basement.
I took it aprt to see what I had, it had green clutch plates, HD clutch springs and a roller pusher. When I pulled the oil pan it looks like the trans was undercut? Also there is what seems to be a windage tray? I hadn't seen this on a bike before. Thoughts??
Attachment crank.jpg not found
Attachment trans.jpg not found
- Injected
Re: windage tray?? undercut trans
06 May 2011 22:37
Drag race components...
1978 KZ650B2 modified project
- wireman
06 May 2011 22:42
tranny doesnt look undercut to me,maybe beat up on one side of dogs unless thats oilim seeing.
got a better picture of trans?
yes thats a windage tray under crank
- 771000KZ
06 May 2011 22:42
Good starting point for a street motor though?
- wireman
06 May 2011 22:47
definately!wipe off the gears and make sure thats just oil on there,id also split the cases and make sure that theres not a lot of gunk sitting on top of the windage tray
- Injected
06 May 2011 23:33
So is the crank welded? What does the head and pistons look like?
- 771000KZ
07 May 2011 08:06
Not sure about the crank, I'll have to split the cases to check that? The head is bare and the exhaust ports look ported but not complete, looks like the project stopped prior to completion. The block is freshly bored to 71mm, and it came with 3 sets of pistons, used 70mm with really hign tops, 71's again with high tops and a set of brand new 72's and a new in box set of rings for each piston set. The 72 set only has 3 pistons the guy lost one. Check out my other posts for pictures. Also has a cet of 28mm carbs from a 73 900.
My project bike is done (first ride yesterday) with the stock 900 motor and it pulls very very hard, I can't imagine what it'll be like when I finish and drop the mark11 motor in!
