Overcautious on cam timing??
- TorreyJ
06 May 2011 21:27
1981 KZ650 H1 CSR.
Maybe I'm being overcautious but when I read the manual for cam timing I'm supposed to line up the strait up and down line. TDC for 1 and 4. Then the front z6EX mark on the front cam and the IN mark on the rear cam...so that's it? is there any way these things could be aligned wrong if those three things are lined up. Oh and 45 links between the marks. It just doesn't seem like the marks line up on the head "parallel?" they seem like they sit above the plane of the level cam surface? any input? thanks!
- Injected
Re: Overcautious on cam timing??
06 May 2011 22:20 - 06 May 2011 23:29
If the marks don't line up parallel with the head then your probably off by one tooth... it will run, but it will run crappy - if there a picture your going by in a FSM it should be as the picture or extremely close...
Being cautious is smart - take your time and check it over 2-3 times...
One thing to check -
If you didn't do it already try bolting the cover on with just the 4 bolts in the center then rotate the motor and unbolt the cover... this might have some effect on where the marks line up when you rotate the motor to check the timing marks.If it does not make a difference then proceed as below.
Unbolt one cam at a time and advance/retard one tooth without actually lifting the sprocket off the chain - that way you don't loose where you are on the chain... if you take the sprocket off the chain entirely you will loose the place you were last bolted up. Check it again... do the same thing if required... don't stop until it looks right.
Keep turning the motor over by hand and checking... with the amount of clearance built into these stock motors it is highly unlikely you will have any collision between piston and valve or valve to valve.
When complete make sure that the cam chain is fully adjusted and not loose...
1978 KZ650B2 modified project
Last edit: 06 May 2011 23:29 by Injected.
