Busted
- roy-b-boy-b
Busted
29 Apr 2011 20:17 - 29 Apr 2011 20:18
I have been working on my bike all week. Bearings brakes carbs. Everything! I rode yesterday and the bike just didn't seem right.
Adjusted valves today and went through carbs again. Something was still wrong.
Pulled the head. Pulled the jugs and found a busted piston.
I have the cases cleaned and ready to install tomorrow with another set of pistons. Bummer.
Last edit: 29 Apr 2011 20:18 by roy-b-boy-b.
- Treewizard
Re: Busted
29 Apr 2011 20:27
bummer indeed
oh well time to bore it out!! :evil:
but what do u mean a 'busted' piston? ,,
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
2002 ZRX 1200R
Raleigh NC
- roy-b-boy-b
Re: Busted
29 Apr 2011 20:29
It was busted between the top and second ring. Must have just happened as the cylinder is not damaged. roy
- trianglelaguna
Re: Busted
29 Apr 2011 23:07
glad your okay
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- KZQ
- Administrator
Re: Busted
29 Apr 2011 23:15roy-b-boy-b wrote: It was busted between the top and second ring. Must have just happened as the cylinder is not damaged. roy
Dude! He's NOT OK! He's busted between the top and second ring. Thankfully his cylinder is ok, it could be worse. :laugh:
Roy, Glad you found it as soon as you did.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- roy-b-boy-b
Re: Busted
30 Apr 2011 06:35
I was going to install my 1075 engine but I wanted to change the head on that engine but I don't have a head gasket for the 1075.
I'm just trying engines out. This engine was one of two I bought and have been running it for two years.
Before all is said and done I might be running the 1075 before the day is over. I will be running something. Roy
- roy-b-boy-b
Re: Busted
30 Apr 2011 16:42
I got the pistons,jugs,and head installed. Hope to be done in a three hours. Roy
- roy-b-boy-b
Re: Busted
30 Apr 2011 21:22
I just need to install the exhaust and carbs. I got a lot done..
Even the dishes and one load of clothes. And the trash.Don't forget the trash. Roy
- roy-b-boy-b
Re: Busted
01 May 2011 14:36
I got the bike fired up and let it idle for a spell.
I have to wait on a cam cover gasket. Blasted smog head. I will plug the holes and let them cure tonight.
This bike is getting to be a bitsa bike. Bits of this, bits of that. Roy
- wireman
Re: Busted
01 May 2011 15:20
- Motor Head
Re: Busted
01 May 2011 19:10roy-b-boy-b wrote: It was busted between the top and second ring. Must have just happened as the cylinder is not damaged. roy
Detonation? Broken piston between lands is usually a sign of the dreaded Knock.
- roy-b-boy-b
Re: Busted
01 May 2011 20:24Motor Head wrote:roy-b-boy-b wrote: It was busted between the top and second ring. Must have just happened as the cylinder is not damaged. roy
Never went through my mind. Been running the same set up for a couple of years.
I'll check everything out, timing ,etc. Thanks for the heads up. Roy
