77 KZ1000 Help..."barn find"
- czombie
08 Apr 2011 21:17
Hey guys....I've recently purchased a 77 kz1000A from a guy and I have a question.
I took the sprocket side cover off to inspect things and noticed that there wasn't a nut holding the sprocket on. I'm assuming the guy I bought it from robbed it and possibly the CORRECT sprocket for one of his other kawi's. Anyways I'm concerned at how much of the output shaft splines are sticking out past the seal face. There are only about 3/8 of an inch of splines exposed and I was just checking to make sure this is the normal allowance. It moves fine in neutral, locks up in gear, normal lash, etc. It just didn't look like enough meat to me for the sprocket to be secure and rigid enough. As a matter of fact the sprocket that was one there still had room left before it would flush up to the edge of the splines. There was still spline room left on the sprocket to slide. Maybe this is the wrong sprocket size...?? Maybe it's normal...?? I have no clue. I'm new to working on bikes, especially Kawi's....
Like I said there's about 3/8 of an inch of splines exposed....Also the guy that I bought it from parked the bike running a few years back. Too old and broken down to ride it anymore. He assured me the motor and everything was sound....But you know how that goes.
thx guys....
thx guys....
- MFolks
Re: 77 KZ1000 Help..."barn find"
08 Apr 2011 21:27
Ask at
www.z1enterprises.com
They are very knowledgeable about these old Kawasaki's.
- JR
08 Apr 2011 21:36
Lots of knowledgeable people here also. Hang around. I'm sure someone with the answer will be along shortly. If you have a chance a photo might help. Welcome to the site
- czombie
08 Apr 2011 21:54
I did early today actually...they looked but couldn't find any specs.
If I don't find out before Monday I'll call redline.
- testarossa
08 Apr 2011 22:06 - 08 Apr 2011 22:07
3/8" of splines sounds about right to me. It would have had a 630 chain as stock. 630 corresponds to a 3/8" wide sprocket. As for the lack of a nut, I guess it could run for a while like that, but I bet it wouldn't end well. It wouldn't be the first time that a neglected bike had lost the nut on the countershaft sprocket. Probably best to replace the chain and sprockets together to eliminate any doubt.
EDIT: BTW welcome to KZR! Post some pics when you find the time.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 08 Apr 2011 22:07 by testarossa.
- czombie
09 Apr 2011 00:01 - 09 Apr 2011 00:01testarossa wrote: 3/8" of splines sounds about right to me. It would have had a 630 chain as stock. 630 corresponds to a 3/8" wide sprocket. As for the lack of a nut, I guess it could run for a while like that, but I bet it wouldn't end well. It wouldn't be the first time that a neglected bike had lost the nut on the countershaft sprocket. Probably best to replace the chain and sprockets together to eliminate any doubt.
thx for the reply man....I feel much better at ease now.
Now I can get started getting this beast runnin.
:evil:
Last edit: 09 Apr 2011 00:01 by czombie.
