oil pressure light
- stonemaster
oil pressure light
19 Mar 2011 20:20 - 19 Mar 2011 20:22
started the bike today and found a leak in the valve cover gasket, so I'm pretty sure i've got oil pressure because of the leak,I let the bike cool down and restarted, after a little bolt tightening the valve cover leak is gone but my oil light stays on, Opinions ???
note it did flicker off a little when first started but came back on
Last edit: 19 Mar 2011 20:22 by stonemaster.
- JR
Re: oil pressure light
19 Mar 2011 23:14
I've had the oil light come on a few times on my 750. First time it happened I feared the worst - oil pump, blockage, low level etc etc. Turned out to be very simple. My oil pressure sensor is behind the timing cover. A single wire connects to the center of the unit. The center connection point is surrounded by a circle of orange coloured non conductive material and if dirty and if this shorts to ground then the light comes on. I used a rag or a kleenex around the orange material and wiped away a layer of grime. No more red light. I think the last time it happened I cleaned and used battery terminal grease (dielectric grease?)on the connection. Might be worth a try before tearing off the oil pan.
Good luck
Good luck
- wireman
20 Mar 2011 00:59
does it go away when you crank the throttle?
- stonemaster
20 Mar 2011 02:04 - 20 Mar 2011 02:27wireman wrote: does it go away when you crank the throttle?
nope
When i did my shim i could tell oil is moving through the motor and the valve cover leak makes me think oil is moving through the engine and that its probably something else, since its a low pressure system, would enough oil get to the top of the motor if there was no or low pressure ????
Last edit: 20 Mar 2011 02:27 by stonemaster.
- stonemaster
20 Mar 2011 04:04
well I found the section on how to check oil pressure with a gauge, (somehow i missed it the first time through) now all i have to do is rig up a oil pressure gauge and I'm set
- wireman
20 Mar 2011 04:45
did you check the sending unit?
- stonemaster
20 Mar 2011 04:58
that'll be first, there's also the possibility that the oil was thinned a little, I've got VM 29's on it and and they have no over flow and u know what that means, so I have a plan, with the certainty that oil is getting to the top of the motor i know its not the oil pump, so I'll get it what do u think about going to 20 w 50 on the oil Jim ???
- wireman
20 Mar 2011 05:11
it shouldnt be an issue with oil viscocity as long as youre running atleast 10w40 ,once it starts getting hotter out you could switch to 50w but i wouldnt rely on it to cure an oil pressure issue.
that little plastic switch unscrews from top of sending unit so you dont need to remove the whole thing from motor.
- wireman
20 Mar 2011 05:17 - 20 Mar 2011 05:19
how long as motor been run since putting it back together?
if carbs are jacked up dumping gas into oil time to pull the plug and change oil,see if its getting washed down with gas.
3 in the morning and im cooking a roast and talking bikes,gotta love this retirement gig! :woohoo:
Last edit: 20 Mar 2011 05:19 by wireman.
- stonemaster
20 Mar 2011 05:18
thanks man, i dont have it on the road yet as I'm testing in my little ass shop with a fan on the motor, I'm poor white trash (with and education and a attitude :woohoo: ) and if i fuck this up Im screwed, so I'm a little paranoid. and god damnit that was supposed to go away when I quit smokin dope, LIFE IS SO UNFAIR
:blink:
- wireman
20 Mar 2011 05:22
yeah i know an old mobster sort of guy who told me his life got so much more complicated when he went legit!
- stonemaster
20 Mar 2011 05:25ABOUT 10 TO 15 MINUTES, I forgot to turn off the petcock and notice some overflow through the air filters,wireman wrote: how long as motor been run since putting it back together?
I had rechecked the valves clearances (after discovering some bad math, thanx larry) so I know oil was getting topside. It was dirty already which isnt a surprise but looked a little thin. I did pre oil the cylinders with marvel mystery oil as I have done in the past, as i said before the light flashed off when motor first started and then came back on, thats why i'm wondering about this "viscosity" issue.
