Exhaust question Please Help!
- Krusty_47
06 May 2010 18:38
Ok I think this is the right place to post this. picked up a KZ1000 Classic. And someone has destroyed the internals of the exhaust or more accurately they are gone except for 1 piece that they have drilled holes into. It's basically a completely open exhaust. Well I run into a problem with that because the Classic is fuel injected so I cannot rejet. I have very little adjustment that I can do to the fuel flow to compensate for the increase in air flow because of the pipe. It's running so lean its turning the pipes purple. The problem I have is I have no idea what type of exhaust it is so I can't put in new internals until I find out what kind of exhaust it is.
I want to increase the back pressure so I can richen the mix. I would just get new stock pipes for it but I can't afford that right now. So can someone on here help me out? If you happen to have the proper end cap and baffle that would be great. Here are some pictures of the exhaust.
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
- Krusty_47
- Krusty_47
- Krusty_47
Re: Exhaust question Please Help!
06 May 2010 18:46 - 06 May 2010 18:50
Here is what they did to the internals of the exhaust.
Now I'm thinking I can at least repair the internal portion I have by cutting out the bottom of it and welding a new piece in there and cut a new hole to match a new baffle size. I was thinking about creating a new baffle unless someone has a cheap one with an end cap that would fit this muffler.
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
Last edit: 06 May 2010 18:50 by Krusty_47.
- 2006hhr
06 May 2010 19:03
That is a Mac Megaphone style exhaust. Mac carries replacement baffles for that pipe, and their replacement baffle for the Kerker Megaphone may fit also. Most likely they drilled the baflle for more sound, tho i cannot see why, the Mac pipe is plenty loud to my sensitive ears.
- Krusty_47
06 May 2010 19:06
this thing would blow your ears out. It's very loud. The problem is there is too much air flow I need to find a way to restrict it.
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
- Kawickrice
06 May 2010 19:10
Unscrew that bolt and pull the baffle out and rewrwp it with some insulation
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- TeK9iNe
- What did you do!?!
06 May 2010 19:17
Kawickrice wrote:
Yep! Done.
Lots oh fibreglass batting, nice and tight!
Yep! Done.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 2006hhr
06 May 2010 20:25
Mac's website has replacement baffles for $39.50, Kerker style is the same price, but until i get my Kerker back i do not know if it will fit.
www.macperformance.com/store/category.cfm?SID=3&Category_ID=738
- Krusty_47
07 May 2010 01:54
Well there is no baffle in there just that plate thats in there. Any tube that would go back into the pipe has been removed.
1976 KZ900 A4
1980 KZ1000 G1
1980 KZ1000 G1
- Mcdroid
- Gone Kwackers
07 May 2010 04:43
If you want, you can find replacement 'stock' pipes relatively inexpensive on eBay...I seem to recall that 900/1000 LTD 4into2 pipes from any year will fit and match style...the difference being the G model has a single cross-over pipe underneath the bike.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- otakar
Re: MAC Exhaust question Please Help!
07 May 2010 06:15 - 07 May 2010 11:30
You have two options with that system. As was mentioned before get the replacement baffle for that pipe. It wil get much quieter. Or you can buy an entire cannister tail pipe for the pipe from MAC. That pipe has a straight cannister and not a megaphone. It will slip right onto your header collector. It will give you a much better mid range (since this pipe that you have is more intended for top end) and be much quieter. I have one on my KZ900 and I love the sound.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 07 May 2010 11:30 by otakar.
